Fuji Fellow Posted April 6, 2004 Share Posted April 6, 2004 I was reading the Divorced Transfer case thread, where some folks from here took their modified Soobs up to Rubicon for some hard-core rock climing. A sub-thread came up about new vs reman axles, and I think it was ZAPAR who suggested starting a new thread about it. So I am. A couple of years ago I slid off wet pavement and kissed the curb with the right front wheel of my 88 wagon. This caused a rather spontaneous rearrangement of the front end drivetrain - scrap one wheel and tire, strut, lower control arm, and axle shaft. My dear State Farm insurance wanted to total the car for this, saying it would cost $2200 to fix (with all new parts of course). I talked them into letting me have the car fixed at my local favorite Subaru junkyard (Jim Reed Motors in Austin, you may have seen this place referenced in another post from me). Anyway, they did a great job on the rebuild. It aligned just fine, and drives just like new. They put in used parts which were in good condition, but now I'm starting to get some axle clicking from the right front when making sharp turns under power. It's becoming apparent the axle shaft they put in must have had quite a few more miles on it than the original. My question: What if any is the risk of just continuing to drive with this axle? I don't do a lot of off-roading, maybe the occasional beach trip. Most of my driving is highway and commuting to work. The clicking shows up only under the sharpest part of a turn, and goes away as I straighten out. Should I go ahead and shotgun this axle, or is it safe to just live with it? Quote Link to comment Share on other sites More sharing options...
calebz Posted April 6, 2004 Share Posted April 6, 2004 They will click for a long time before they break. New is better than the average reman.. However I have heard very good things about www.cvaxles.com You got a couple of years out of a used axle.. thats not bad.. I got 8 months out of a nice fresh reman I just had to replace. Next time they offer to toal your car like that, let them.. then take the cash and buy it back for $25 bucks and fix it.. you will still have cash in your pocket Quote Link to comment Share on other sites More sharing options...
88xt6joe Posted April 7, 2004 Share Posted April 7, 2004 Mine clicked for nearly 10,000 miles before they broke in my wagon. I just put one's in from www.cvaxles.com and I would highly recommend them. They are very easy to work with on the core charge and very good prices. Joe Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted April 7, 2004 Share Posted April 7, 2004 drive it until it breaks, stop when it violently shakes the car if you continue, you risk breaking brake line, and other parts in its path of destruction rebuilt with new stub and neoprene boots Quote Link to comment Share on other sites More sharing options...
archemitis Posted April 7, 2004 Share Posted April 7, 2004 10thousand miles, while clicking is not unheard of. i have never sheared one ever, they always click, or wobble for me. junkyards! Quote Link to comment Share on other sites More sharing options...
subarubrat Posted April 7, 2004 Share Posted April 7, 2004 Man, it is just an axle. Go to Autozone and fork over $80 and get a new one. End of drama, end of problem. If you need to wait till the end of the month, do so without any real worry that the clicking one will fail in that time. Best yet, replace it yourself, it is easy. Quote Link to comment Share on other sites More sharing options...
edrach Posted April 7, 2004 Share Posted April 7, 2004 Another vote for www.cvaxles.com. However, they click for a long time. Check the rubber boot it's probably torn; if not, it'll last quite a long time. When my son's roommate lost a front axle, he called and I went out with an old coat hanger and tucked the axle out of the way, put the car in 4WD and drove it home. Fixed it with another junkyard axle. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted April 7, 2004 Share Posted April 7, 2004 Bragging time.... Today I replaced the pass side axle on a 95 FWD Auto Legacy in 28 min and the drivers in 21. Yesterday I did the pass side one on the Brat in 31 min. Clicked when turning hard left was left axle today. Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted April 7, 2004 Share Posted April 7, 2004 i give a thumbs up to cvaxles. the made custom ones for me! Quote Link to comment Share on other sites More sharing options...
ShawnW Posted April 7, 2004 Share Posted April 7, 2004 Oh me too (CVAXLES), custom ones for me too. RX (turbo spline) inner with Ea81 outer. great boots! Quote Link to comment Share on other sites More sharing options...
Fuji Fellow Posted April 7, 2004 Author Share Posted April 7, 2004 Hey ShawnW, Great advice you and everyone have given here! It's ok to brag. Brag with some more details, if you would... what sequence of steps to replace the axle, since it can be done by the home mechanic? James Quote Link to comment Share on other sites More sharing options...
v8vega215 Posted April 8, 2004 Share Posted April 8, 2004 I wouldnt worry too much about the noise, in my 79 brat the two fronts shake the car violently every time i let the clutch out and the two rear ones have been clicking and banging around. the car still drives just fine other than that, and i have been putting 3000 miles per month for about 7 months. side note: all 8 boots are missing. too lazy to put my new axles in. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted April 8, 2004 Share Posted April 8, 2004 Jack the car up, chock tires. Remove wheel, remove axle nut. Remove 14MM ball joint bolt. I use a gorilla bar (long pry bar) and pop the knuckle off the balljoint just below the 14MM ball joint to knuckle bolt. Then I approach the axle pin. I take a 10MM deep metric impact socket, stick the punch into that (fits perfect) and then stick an appropriate amt of extentions onto it so I can hammer on the "extended" punch easier. Then you can slide the axle off the inner stub. Then you persuade the axle out of the bearings (alot easier on a Legacy) by tapping the end of the axle with a hammer (protect threads with woodblock or use a plastic deadblow hammer). Once the axle is out its a reverse of the removal. Applying a little wheel bearing grease to the axle end makes the slide in easier. The control arm can be popped back into the knuckle pretty easy by either tapping again with the deadblow hammer or by using a floor jack gently. I find the 2nd method to be a little dangerous but it works well. (courtesy of MilesFox on that tip). I use Air tools for the axle nut and 14MM ball joint bolt. Lots faster. HAND torque lug nuts especially on legacy models as this will screw up your brake rotors. It will warp them rather quickly. Quote Link to comment Share on other sites More sharing options...
subarubrat Posted April 8, 2004 Share Posted April 8, 2004 I use a 2 foot long piece of 5x5inch wood that I keep just for pounding out axles. It really is just as easy as Shawn says. You can also do it without removing the ball joint but it is easier to get the shaft off at the tranny. Quote Link to comment Share on other sites More sharing options...
StormTrooper Posted April 9, 2004 Share Posted April 9, 2004 I had my front left axle blow out on me when I was getting off the freeway. It had been clicking big time for a few weeks, and then the rain came... Luckily, it still held the shaft into the cup, so when I drove, the shaft did'nt fly around clipping brake lines and etc.. I put it into four wheel drive, and drove it to work, where I drove the axel pin out and remnoved the axel in three minutes since i didnt have to loosen any suspension components. I have been driving a rerar-wheel drive wagon since (man are donuts fun!) Quote Link to comment Share on other sites More sharing options...
