81EA81 Posted November 10, 2012 Share Posted November 10, 2012 Hi, I have an 84 Gl 4WD 4sp dr wagon. Recently my turn signals would no longer flash,My hazards would stay steady too. So I assume I need to replace the flasher. After a bit of thumbing through a Haynes manual and poking around the dash I think Ive found it. Dose this look like a flasher?It was tucked up above the fuse box mounted vertical. Any input is appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
jonas Posted November 10, 2012 Share Posted November 10, 2012 Could be. Try using your signals with it out. Shouldn't work at all. Here's a pic of a replacement. They're dirt cheap. Quote Link to comment Share on other sites More sharing options...
81EA81 Posted November 11, 2012 Author Share Posted November 11, 2012 Thank you! I've come to the conclusion this is indeed the flasher. I will replace it tomorow and I will include a pic of its location for future searches. Quote Link to comment Share on other sites More sharing options...
noahkort Posted April 30, 2013 Share Posted April 30, 2013 (edited) Did this one the other day, in this photo the fuse box bracket is removed and the flasher is way up in there around the arrow. The the flasher bracket didn't attach to my replacement flasher from rock auto, so it's just floating around in there, no biggie. Pain in the butt to find, hope this helps the next guy. Edited April 30, 2013 by noahkort Quote Link to comment Share on other sites More sharing options...
