Gloyale Posted January 1, 2013 Share Posted January 1, 2013 (edited) Does anyone know if the Forrester XT taller 5th gearset will fit the into an old XT turbo FullTime 4wd w/difflock box. The reason I ask, is I want a taller 5th Gear, without loosing much on the 1st gear crawling side. My current trans is 4.11 AWD from 96 outback, cable/push clutch. 1st is O.K., but could be lower....definately don't want much taller. Final drive in 1st is 14.57, in 5th it's 3.206 IF the Foz XT 5th gear will fit onto a 3.7 Turbo FT4wd gearbox....the ratios would be this Final drive in 1st= 13.1165, and in 5th= 2.7306:headbang: Yeah....that would be much taller for the MPGs. 1st a bit taller too....but should still be o.k. This would all be going into an EJ swapped 86 wagon. The thing I don't have an answer on, is how similar are the shaft diameters, shift collar diameters, etc....from the old FT4wd, to the 2nd gen, pull clutch type AWD trans in the Forrester XT??? Edited January 1, 2013 by Gloyale Quote Link to comment Share on other sites More sharing options...
el_freddo Posted January 2, 2013 Share Posted January 2, 2013 This is only what I have read, so it's not experiential nor confirmed on my part: The L series 5th gear isn't interchangeable with the EJ 5th gearset - apparently the shaft diametres are different. But I don't know if this runs true for the L series AWD lockable centre diff gearbox. My gut feeling is either as well which is of no use. Again, what I've read is that the L 5th isn't compatible with the EJ 5th, that's about all I can give you without you investigating further. Regards Bennie Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 2, 2013 Share Posted January 2, 2013 The guy in Colorado with the EJ swap and 4.111 D/R Trans that was built years ago (I forget his screen name...) had a Forester 5th in it. Not sure if it was phase 2, but it almost had to be. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 2, 2013 Author Share Posted January 2, 2013 The L series 5th gear isn't interchangeable with the EJ 5th gearset - apparently the shaft diametres are different. But I don't know if this runs true for the L series AWD lockable centre diff gearbox. I know the FT4wd EA boxes, and the Phase I EJ AWD boxes share lower shaft diameters, and I'm sure Gears can be swapped from EA FT4wd and phase I EJ AWD. Just really need to know about the Phase I / Phase II compatibility. Thanks for the responses. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 3, 2013 Share Posted January 3, 2013 I might have a phase 2 box from a '99 Outback open and partially apart at work. Not a fozzy gear set but would be a phase 2 box nonetheless... Quote Link to comment Share on other sites More sharing options...
