harpua Posted April 10, 2004 Share Posted April 10, 2004 Well while i wait for my weber adapter plate to come for my ea82 intake, i need to get my car running. Has anyone swaped an EA81 intake onto an EA82 motor? I have read up on this, and have found that the intake will fit, but that is about it. I am just looking for info on any big issues that i may run into so that i might be a little bit more prepared. Thanks for all responses. Quote Link to comment Share on other sites More sharing options...
n7zum Posted April 10, 2004 Share Posted April 10, 2004 it'll work no problem... done it....still going strong...just have to use a different upper Radiator hose...that's about it.. mark Quote Link to comment Share on other sites More sharing options...
mcbrat Posted April 10, 2004 Share Posted April 10, 2004 Chef Tim has one set-up that way too.... Quote Link to comment Share on other sites More sharing options...
harpua Posted April 11, 2004 Author Share Posted April 11, 2004 Well i got it all hooked up without too much trouble. I went to start it and the engine turned over for about 3 seconds and then stopped. I turned the key again and all i got was a *click* and the car didn't turn over. Now that is all that happens....turn the key *click* then nothing. Any thoughts as to why this would be? Quote Link to comment Share on other sites More sharing options...
subaruloverbrad Posted April 11, 2004 Share Posted April 11, 2004 did you use new intake gaskets? did you drain coolant before you took of intake? i changed my carb and intake, not exactly like you are doing, had same problem, water was leaking into the engine and hydro locked it. had to remove spark plugs to get it to turn over . then found the water was leaking past one of the old re-used gaskets. replaced them and now it works fine. Just a thought. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted April 11, 2004 Share Posted April 11, 2004 Could just be a totally un-related electrical problem that just cropped up. Or,,, It could be a water leak at the manifold gasket(s), which have the engine hydro-locked. Pull your spark plugs, checking for coolant as you do, then try cranking it again. If it turns over, and sprays coolant all over the place, you have found the problem. Should be evidant as to which side needs more attention. Quote Link to comment Share on other sites More sharing options...
harpua Posted April 11, 2004 Author Share Posted April 11, 2004 Well i pulled the plugs, and found the the drivers side has fluid in the cylinders. I can't tell if it is coolant or fuel, but there is definatly something in there. With all of the plugs out, i try to turn the key over and still just get the *click* from the starter, and the car does not turn over. Could i have fried my starter when i tried to start the engine the first time with coolant in the cylinders? Why would the starter just click and not turn over? I am going to go fiddle with it some more....maybe i can figure something out. thanks for the input so far, i really appreciate it. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted April 11, 2004 Share Posted April 11, 2004 Did you disconnect the BATT when you did all this? Sounds to me like the starter isnt getting enough juice. Also check for hydrolock as well, but I would think it'd take alot more than 3 cycles to completly lock a cylinder, expecially with a leaking gasket. -Brian Quote Link to comment Share on other sites More sharing options...
harpua Posted April 11, 2004 Author Share Posted April 11, 2004 i thought i wasn't getting enough juice to the starter, so i cleaned the battery connections, made sure the starter was hooked up well, still nothing, so i tried jumpstarting the car. still nothing. There is definatly coolant in the cylinders on the drivers side. so there is a chance that i hydro locked it, and fried my starter maybe? who knows, i am pretty frustrated at this thing...getting ready to go postal on it.... Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted April 11, 2004 Share Posted April 11, 2004 If it still clicks then i doubt the starter is fried. Pull all 4 plugs then try to turn it over, if it wont then its not hydro-locked. You might also want to try tapping the starter with a hammer or something to try to free it up. -Brian Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted April 11, 2004 Share Posted April 11, 2004 use a siphon gun and suck out the fluid, turn crank with socket or by pulling belts, starter may be stuck, battery may be weak Quote Link to comment Share on other sites More sharing options...
