eulogious Posted January 9, 2013 Share Posted January 9, 2013 (edited) Didn't see one of these for 2013 so I thought I would start one. Post up some specs and pics of your lifted soobie! ******EDIT******* PLEASE ONLY POST IN THIS THREAD IF YOU ARE POSTING YOUR CAR. DO NOT MAKE CONVERSATION OR ADD COMMENTS, THEY WILL BE DELETED. SEND THE OWNER A PM IF YOU LIKE HIS/HER CAR OR HAVE A QUESTION. Thank you. ********edit***** I just lifted mine this last weekend: 1990 Leggy LS 3" SJR Lift 07/08 Forester Struts 235/75/15 Nexen Roadian MT Outback Steering Shaft EJ22 Stock Rear LSD (not installed, yet :cool:) 4EAT w/ Paddle Shifters and DCCD 12.5" at the Diff Edited January 11, 2013 by Zap Quote Link to comment Share on other sites More sharing options...
one eye Posted January 10, 2013 Share Posted January 10, 2013 (edited) Butters 8" Jaw lift in pic 31X12.50X15 thornbirds usually TSL 31X10.50X15s extended Raidus Arms EA81 Turbo pipe Exaust Yellow Paint Custom bumpers Six lug covertion roof rack 94 Impreza 2" JAW lift 27X8.50X14s 83 Brat 4" lift 27X8.50X14 pugs weber Road Queen Built by Rickdonkuless 7"Jaw lift 265/55/16 Compass tires custom bumers Wifes car 2" Jaw lift 27s' Pugs welded rearend white Frieght 2" Jaw lift now has 27's on it drilled steel wheels SPFI EA81 Welded rear The Red now black and red brat 4" Jaw lift 30X9.50X15 TXR Wild countrys welded rear Jeff Edited January 19, 2013 by one eye Quote Link to comment Share on other sites More sharing options...
Idasho Posted January 10, 2013 Share Posted January 10, 2013 Mine is a bit of a cream puff, so it does go off road much. But its lifted! 1984 GL High compression ea81 weber 5-speed D/R swap 3" lift Custom bull-bar Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted January 10, 2013 Share Posted January 10, 2013 (edited) Michelle ;-) 2.25ish inch lift Straight Pipe cat back 2.25" New Exhaust tip: -Justin Edited January 10, 2013 by crazyman03 Quote Link to comment Share on other sites More sharing options...
JacksonRally Posted January 10, 2013 Share Posted January 10, 2013 (edited) 1000% new for 2013. First trip out in the Jackson Rally Forester 1.1.13 Big Bear Lake JR 5'' lift Custom JR 10'' travel 50mm inverted struts STI 5x114.3 hubs/knuckles all around STI lower control arms and lateral links STI front axles Custom Summers Bros. rear axles (r-160 to sti knuckles) JR roof rack Baja Designs 6'' HID lights and a ton of other little goodies Edited January 10, 2013 by JacksonRally Quote Link to comment Share on other sites More sharing options...
mcbrat Posted January 10, 2013 Share Posted January 10, 2013 '82 Brat GL 2003 Baja this is an old pic. it now sits about 2" higher than this due to new springs and struts for an '05 baja, so technically it's lifted 1" over stock specs.... and just for kicks... 1972 Chevy K-20 with 4" lift. Quote Link to comment Share on other sites More sharing options...
88Subi4x4 Posted January 11, 2013 Share Posted January 11, 2013 9" BJ Lift Pugs running 31x10.5 15's BFG Mud&Snow EJ2.2 Swap Custom rear bumper Warn winch front bumper in the works roof rack Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted January 11, 2013 Share Posted January 11, 2013 AdventureSubaru - 1997 Impreza OBS 3/8 HDPE Spacers 99 Forester Strut Spring lift Chrysler Sebring Steel rims on 215/75/15 LT tires 97 Legacy Outback control arm brackets Quote Link to comment Share on other sites More sharing options...
Vegablade Posted January 11, 2013 Share Posted January 11, 2013 (edited) Not Much Has Changed In The Stable For This YearWill Update After Wagon Gets Tweaked1985 GL Wagon 4WD6" JAW Lift 235/75/15 Maxxis Bighorns on 15x8 Les Schwab Steels. 6 Lug SwapWeberetc..... 1983 Brat 4WD4" LiftHolleyetc... Edited April 26, 2013 by Vegablade Quote Link to comment Share on other sites More sharing options...
bratman18 Posted January 11, 2013 Share Posted January 11, 2013 1998 Forester S 2" Home made lift 215 70 16 tires a bunch of other stuff Quote Link to comment Share on other sites More sharing options...
AKghandi Posted January 12, 2013 Share Posted January 12, 2013 (edited) 87' GL-10 turbo with 3.9 dual range2"boss lift215/75/r15 snow tires. 86 GL 2" lift 29" BFG mud terrain KM2. dual range manual everything basic as basic gets Edited March 7, 2013 by AKghandi Quote Link to comment Share on other sites More sharing options...
maozebong Posted January 17, 2013 Share Posted January 17, 2013 storm trooper: rusty ohio body 2" lift spfi EA82 ported heads MSD SCI/blaster SS 2" straight pipe. wideband o2 wired to ecu, avg 23mpg loaded, 30-32 unloaded. f-stone destination AT 215/75/15. Quote Link to comment Share on other sites More sharing options...
Markus56 Posted January 19, 2013 Share Posted January 19, 2013 (edited) 91 leggo 4"lift with outback struts 215/75r15 BFG mud terrain km2s 4eat with lockup switch Edited January 22, 2013 by Markus56 Quote Link to comment Share on other sites More sharing options...
89ChevondaSI Posted January 22, 2013 Share Posted January 22, 2013 currently not running and waiting on EG33 swap,new trans, and 6" more lift OB struts 1" subtle solutions strut top spacers forester springs in the rear LT215/75R15 hankook dynapro m/t's lotsa other stuff. just cant think of it right now. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 22, 2013 Share Posted January 22, 2013 Same rig with a few improvements for 2013. updated lights, and skidplate mounts, new turn signals, needed after the last snow excursion, getting stuck on a tree. Some new subframe/slider/reinfrocement/carrier bearing support work. Again, needed after the previous carrier mounts ripped out of the body on the last snow trip. And I finally got my long travel nitro charged bilstiens in, and the flex adjusted perfect. Drivetrain: EJ18 5spd 3.9 D/R trans Welded rear EA82 front suspension, Knuckles, Brakes, RX springs. EA82 PS w/EJ pump Dual E-brakes, front Disc brakes, rear Snorkle CB radio 235/75/15 Maxxis bighorn or Isuzu redrilled rims. Quote Link to comment Share on other sites More sharing options...
tundrabrat Posted January 25, 2013 Share Posted January 25, 2013 85 GL 2" boss lift Front RX springs Rear FWD shocks and springs 14" Pugs 26" tires Quote Link to comment Share on other sites More sharing options...
97preza Posted January 28, 2013 Share Posted January 28, 2013 Hey Adventure, do you have any issues with the angle of your axles with the forrester struts/springs??? i have a 97 impreza OBS iwth 98 legacy outback struts/springs on mine but want more but was worried about the axle angles. One extra picture of my youngest napping while we stopped for a break Quote Link to comment Share on other sites More sharing options...
Pooparu Posted January 31, 2013 Share Posted January 31, 2013 Quote Link to comment Share on other sites More sharing options...
UraBUS09 Posted January 31, 2013 Share Posted January 31, 2013 Ea82 wagon 4'' homemade/custom lift resealed motor ported heads 14'' pugs with 27'' SSRs Good and dirty in this pic! Quote Link to comment Share on other sites More sharing options...
2.5LOYALE Posted February 1, 2013 Share Posted February 1, 2013 *1992 Subaru Loyale Wagon -2 inch JAW Lift -2002 Subaru 2.5L Ej Engine With Goodies/ Full OBD2 Readout -215/70/15 BF GoodWrench Radial T/A's -Re-drilled Toyota 6 Lug Rims -Disk Brakes All Around -D/R Swap -Yakima Roof Rack -Sweet Early 90's Wind Deflector:headbang: *and of course my pitty aubrey:drunk: Quote Link to comment Share on other sites More sharing options...
tron Posted February 5, 2013 Share Posted February 5, 2013 (edited) 93 impreza 1.8 6in sjr lift D/R 5 speed 205/75/15 studded Edited February 5, 2013 by tron Quote Link to comment Share on other sites More sharing options...
superu Posted February 8, 2013 Share Posted February 8, 2013 Update for 2013: AUDM D/R 5MT with 4.11 FD and 1.447:1 low 1" angle iron welded at pinch weld (aka subaru sliders), ads regidity and protection new paint and vinyl (some pix new others a may be repated from previous years AND capability Lockhart Basin train IN AN AWD SUBARU, 100% factory subaru suspension and drivetrain! 1 Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 17, 2013 Share Posted February 17, 2013 (edited) Here's some pics of mine during the intermission of today's wheeling trip. 81 Subaru DL Hatchback 8" lift EJ22 ammo can ECU box in spare tire area snorkel 5 Speed DR EA82 front suspension legacy rear inner DOJ's on stock rear axle shafts rear disk brakes divorced nissan transfercase 4.11 gears front and rear,rear is welded 31x10.50x15 mud tires redrilled rims Edited June 11, 2014 by Uberoo Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 17, 2013 Share Posted February 17, 2013 (edited) The street car/ daily commuter 2" HighGuys lift 12k miles on rebuilt 94 Ej22 4.11 AWD trans from 96 outback 215/65/15 Nokian snows on redrilled Yota rims Rear disc brakes XT turbo sway bars front/rear 96 outback 2.2 ECU w/ obdII and working EJ cruise control Swing out spare tire mount Heated outback seats CB radio Folding fog lamps Led front turn signals LED interior lights Outback limited exterior two tone paint and badging Edited February 17, 2013 by Gloyale Quote Link to comment Share on other sites More sharing options...
scoobyclimbs Posted March 13, 2013 Share Posted March 13, 2013 '98 forester S model 2.5l , perrrin crank pulley, borla header, gutted cats, magnaflow muffler 4eat , hayden trans cooler 2.5" lift via king springs + 1" strut spacers , rear struts '03 sg kyb excel -g MB 15" alum wheels, 215/75R15 hankook dynapro rt03 m/t Primitive skidplate modded for borla header custom roof basket rigid industries lights(bumper) indash cb, '01 subaru weatherband am/fm/cd, jbl speakers Quote Link to comment Share on other sites More sharing options...
