rough running, cyl 1&2 misfire
2007 Forester 4-cyl manual NA
CEL and flashing cruise came on, figured it was because it was overdue
for an oil change. Off and on, but most of the time on. Went off when
changed the oil but came back a day or two later. Suddenly begins to run
very rough and CEL begins to flash on way home.
Codes:
p0420 (cat efficiency low)
P0301 (cyl 1 misfire)
P0302 (cyl 2 misfire)
and the MIL readings:
Misfire
Fuel
Comp
Cat
Evap
O2 Sensor
O2 HTR
EGR
quite a list. where to start? are some of these codes being thrown on
account of the more serious codes (ie misfire causing o2 sensor reading
to be funky, etc)
Those are emissions monitors that are set as part of the emissions testing readiness checks. Nothing to worry about there.
P0420 is probably on because of the misfires. Probably just needs new spark plugs. How many miles on the engine, and when were the plugs changed last, if they've ever been changed?
put new spark plugs in today. the old ones didn't look that bad although the passenger side rear plug (sry, i'm new to subarus, don't know which cylinder that is) had a little bit of oil on it. the gap didn't look noticeably out of spec. once installed i started the car again and it still runs like garbage.
That would be number 3.
3------4
1------2
Front
The valve cover grommet is leaking and will need to be replaced fairly soon or it will short that spark plug and cause misfires. That could possibly be a cause of the current misfiring.
Does that engine have spark plug wires or individual coils mounted directly on the plugs?
That's the only source of oil in spark plug wells. If it were another leak it would make a huge mess all over the engine before getting into the plug well.
Have never heard of twisting plug wires. Kinda sounds like bird to me.
Swap the plug wires front to rear and see if the misfire codes follow them. Or if they look old just replace them.
