Dazed Dreamer Posted March 14, 2013 Share Posted March 14, 2013 I am working on a friends 1992 Subaru legacy and she was given a 1.8 motor from an impreza because her engine was blow, my question is can I just swap the engine harness and have everything be ok? will it run? will it run bad? will it pass Colorado State Emission Laws? Quote Link to comment Share on other sites More sharing options...
Subruise Posted March 14, 2013 Share Posted March 14, 2013 you need to use the search function. whether or not, and how well, depend on what years the two motors are from. if they are from the same gen, itll be plug and play. if not....well back to searching Quote Link to comment Share on other sites More sharing options...
987687 Posted March 14, 2013 Share Posted March 14, 2013 Put the 2.2L intake on the 1.8L engine and swap the knock sensor onto the 1.8L engine. Then it will directly bolt in. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 14, 2013 Share Posted March 14, 2013 what he said, it's very easy. no wiring swap. remove the entire intake manifold with wiring off the EJ18. install the EJ22 intake manifold (with new gaskets) onto the EJ18 engine - installing the knock sensor while you're at it. done. I'm assuming they both have EGR, i think EJ18's always do so you should be fine... good time to just get a new knock sensor off ebay for $20, they fail fairly often. i'd also be installing a new timing belt kit - $80 off ebay for all new belt, tensioner, pulleys. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 14, 2013 Share Posted March 14, 2013 You will need to plug the egr port in the EJ18. Drivers side head in the back. Other than that its drop in. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 14, 2013 Share Posted March 14, 2013 another Ej18 into EJ22 thread: http://www.ultimatesubaru.org/forum/topic/117057-ej18-95-into-a-96-lego-l-sedan-both-auto-awd/ Quote Link to comment Share on other sites More sharing options...
