Yet another tranny swap question
Yes, it will bolt-up.
You might need to use an EA81 flywheel though, because the EA71s all used the small clutch.
An EA82 flywheel might also work, but the bolt holes will be a size too large and the EA71 bellhousing might need ground down a little to make it fit.
