phillys14 Posted May 16, 2013 Share Posted May 16, 2013 I know this has been discussed before, but I have a 97 Impreza with the check engine light on. I keep getting the codes po440 evap malf and p1441 evap vacuum cut valve. I can clear the codes, but they just pop up again later. It hasn't caused me an issues and mechanics haven't been able to solve this. Is this something that is an easy fix or a bigger project I should be worried about? Quote Link to comment Share on other sites More sharing options...
davebugs Posted May 16, 2013 Share Posted May 16, 2013 IIR a bad fuel filler tube will cause this. Quote Link to comment Share on other sites More sharing options...
palfer Posted August 9, 2020 Share Posted August 9, 2020 did you get the evap code issues solved? Quote Link to comment Share on other sites More sharing options...
