Someperson Posted August 8, 2013 Share Posted August 8, 2013 So, I can't get a definitive answer about what i'll need for a crossmember to drop my ej22t into my xt6. I was told an ea82t crossmember would be workable and i've gotten conflicting info there stating that the xt crossmember won't bolt up to the mount holes in the 6... anyone here done the swap before? Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted August 8, 2013 Share Posted August 8, 2013 (edited) If you do choose the EA82T cross member the lower control arm pockets will likely be a problem. The bushing area on the lower control arm will probably rub, and the XT6 bolts won't fit unless you drill the holes out. It might just be easier to notch out the XT6 cross member to clear the EJ22T exhaust. I don't know about the XT4 part. Edited August 8, 2013 by Crazyeights Quote Link to comment Share on other sites More sharing options...
john in KY Posted August 8, 2013 Share Posted August 8, 2013 Ask Huck 369 over on the XT6 forum what he had to do to install a SVX engine in his XT6. Just from memory I seem to recall in was pretty much a drop in with the right motor mounts. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted August 8, 2013 Share Posted August 8, 2013 Ask Huck 369 over on the XT6 forum what he had to do to install a SVX engine in his XT6. Just from memory I seem to recall in was pretty much a drop in with the right motor mounts. An SVX swap won't help with the EJ22T up-pipe though, will it? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 8, 2013 Share Posted August 8, 2013 Bah, come on guys. What ever happened to that sticky about not answering if you don't know?! A 4-cyl (XT or otherwise) and 6-cyl engine crossmembers have completely different bolt spacing (front to back) than each other. They are not a bolt-in replacement. If you were to lay the 2 crossmembers next to each other, the XT6 one would be much "wider" (across it's narrowest horizontal dimension, which would be front-to-back in the car), this is why the XT6 sway bar is shaped differently, and pulls the end links back and a funny angle when used on an EA82 car. Now, I have not swapped them (personally...I don't see the point. You have the engine bay for an EG33.....but each to their own), but knowing that the control arm mount is near the rear. And the basic geometry (leading rod mounts, transmission crossmember, etc.) is all the same from a 4-cyl, I suspect the rearward hole would line up correctly, and the front hole on the crossmember would not reach to the bolt through the framerail. So I suspect one could use the 4-cyl crossmember as a template to drill 2 new holes in the frame rail, and from there everything would bolt up. This would probably be considerably easier than notching the XT6 crossmember. 1 Quote Link to comment Share on other sites More sharing options...
Someperson Posted August 8, 2013 Author Share Posted August 8, 2013 How much heavier is the eg than my 22t? I'm going for power to weight ratio, also like the 4cyl because of fuel consumption 1 Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 8, 2013 Share Posted August 8, 2013 I have an xt6 crossmember in a gl coupe, which is opposite of what you are doing. I had to drill a hole on eaither side of the xt6 member to fit my frame. It should be the rear part of the frame lines up, so line up the holes, and drill new ones to match the body. You may want to consider using the studs from a normal body and drilling through the framerail on the xt6 to match the turbo crossmember. The hole spacing on the body may be too far apart for the crossmember. Either way, depending on where you drill holes, it will match up to the body. You will have to rely on your skills to attach it, but the dimensions are there to work with. There may be differences where the power steering rack mounts such as swapping lines over. Depending on the rack. You may have to remove the external hard lines on the turbo crossmember, and if using the xt6 rack, you may have to make a 2nd hole on the crossmember for the steering line hook-up since later steering racks run along the rack instead of external hardlines. This may be different depending on what year your parts are. I had an 86 body using 89 parts going into it. There are a few structural difference from 86 bodies from 87 and later due to the introduction of 4spd auromatic trans in 87/88 Quote Link to comment Share on other sites More sharing options...
Someperson Posted August 8, 2013 Author Share Posted August 8, 2013 Mine's an 89, and i may end up with a diff h6 out of convenience and my end power goals. I'm basically testing the waters on this new platform. Just want to know how easy/hard the swaps are Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 8, 2013 Share Posted August 8, 2013 Here are some posts from my build that highlights the crossmember http://www.ultimatesubaru.org/forum/topic/115300-86-3door-runaboutfwdft4wd-4-lug5lug-ea82-carbej22-or-er27-swap-rust-removal/?p=992336 http://www.ultimatesubaru.org/forum/topic/115300-86-3door-runaboutfwdft4wd-4-lug5lug-ea82-carbej22-or-er27-swap-rust-removal/?p=1000253 Quote Link to comment Share on other sites More sharing options...
