jeryst Posted August 22, 2013 Share Posted August 22, 2013 Just bought my sons 97 Impreza Outback Sport. It runs fine right now, and only has 106k miles, but I'm thinking ahead. The car is almost rust free, and I really like it, so I was thinking of making it a little more fun when the time comes. Quote Link to comment Share on other sites More sharing options...
davebugs Posted August 22, 2013 Share Posted August 22, 2013 Not sure a Subaru was really meant to be a "speedy car". But it has proved to be a reliable car - especially the 2.2 if left stock. Some folks here install 2.5 heads on them. I'm not sure if a tune is available. I have a CAI and 2.5 heads if you're local and want to mess with the engine yourself. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 22, 2013 Share Posted August 22, 2013 (edited) Just bought my sons 97 Impreza Outback Sport. It runs fine right now, and only has 106k miles, but I'm thinking ahead. The car is almost rust free, and I really like it, so I was thinking of making it a little more fun when the time comes. I think the best approach would be to swap in a WRX or possibly an STI engine. check over at NASIOC for lots of info on stuff like that. But, even as is, some suspension and brake and tire upgrades could make the car a lot of fun to throw around the corners. Anything can be made faster with enough $$$ ,but, 'the Man' doesn't let you go too fast on his roads, he doesn't really care how flat you can turn corners though! Edited August 22, 2013 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 22, 2013 Share Posted August 22, 2013 With only 106k miles you still have a LONG time to think. Change the timing belt, idlers, and water pump on time. Take care of oil seals and gaskets that like to leak. Keep up with regular oil and fluid changes and you'll get 300k out of that 2.2 with no trouble. If you need some extra oomph in the meantime, get a set of delta torque grind cams. Or put a 2.5 block in between the existing heads and manifolds. (Called a frankenmotor) That's usually good for another 30-40 horses. There's also a the option for a turbo swap, but you'll be spending $$$$ on engine and drivetrain to handle turbo power. Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted August 26, 2013 Share Posted August 26, 2013 With only 106k miles you still have a LONG time to think. Change the timing belt, idlers, and water pump on time. Take care of oil seals and gaskets that like to leak. Keep up with regular oil and fluid changes and you'll get 300k out of that 2.2 with no trouble. If you need some extra oomph in the meantime, get a set of delta torque grind cams. Or put a 2.5 block in between the existing heads and manifolds. (Called a frankenmotor) That's usually good for another 30-40 horses. There's also a the option for a turbo swap, but you'll be spending $$$$ on engine and drivetrain to handle turbo power. Bad water pump killed my 2.2 at 130k. Quote Link to comment Share on other sites More sharing options...
