Frankenmotor: which timing belt... Stupid Question, Couldnt find the answer..
xbeerd
How many teeth should the timing belt have for a frankenmotor setup?  i looked on Rock auto,  they listed a 223 tooth belt for a 99 sohc 2.2l and a 211 tooth belt for a 95 2.2l.   im running 99 2.5block with 95 22heads
currently im just running the belt that was on the junkyard '95 ej22.
ok, thanks for the clarification.  makes sense that it should match the heads if the blocks are all identical.
its running well but i wanted to replace the belt just cuz the one on there has been sitting in a junkyard for a couple years on a shelf
