99 forester parts fit 95 sedan
the engine in the 99 forester is a phase 2 SOHC ej25,
it will not swap into a 95.
the trans will not swap UNLESS you used the matching rear diff as well.
so you are limited to wheels, knuckles, spindles, struts, axles, brakes, wheels, tires, and maybe some of the drive shaft.
but there are conditions on some of the above parts like,
larger brakes require larger wheels.
larger tires require taller struts.
the 99 forester is not a good choice as a parts car for a 95 lego.
a 96 - 98/9 outback would be a much better choice.
Edited by johnceggleston
