hansonworld2003 Posted October 4, 2013 Share Posted October 4, 2013 1990 Legacy wagon starts up, drives for about 30 minutes in rain or wet snow, then starts misfiring and dies. Will start right back up, but acts as if not running on all cylinders. Tach all over the place but no power. Can sit for awhile, then nurse it a couple more miles and it dies all over again. Replaced spark plug wires, fuel pump. Is there a crankshaft position sensor that could be getting wet? Suggestions? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted October 4, 2013 Share Posted October 4, 2013 coil pack?? Quote Link to comment Share on other sites More sharing options...
TOONGA Posted October 4, 2013 Share Posted October 4, 2013 it could be the coil pack or the ignition relay(well hidden under the dash orange relay) or the igniter(under bonnet) Have you checked for codes? TOONGA Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 5, 2013 Share Posted October 5, 2013 Get it warmed up one night and most some water (spray bottle) on the coil pack, look for sparklies. 1 Quote Link to comment Share on other sites More sharing options...
heartless Posted October 5, 2013 Share Posted October 5, 2013 Get it warmed up one night and mist some water (spray bottle) on the coil pack, look for sparklies. Do this ^ waiting until after dark makes the spark easier to see. Also mist a little water around the spark plug end of the wires. If you used a cheap set of wires you could have one that is jumping spark to the block. I had that happen to me before on my 1990 EJ22 - it was so bad that I could see it in broad daylight! Had to wrap the boot with electrical tape to get to where I was going & get another set of wires. No more cheap wires for me! the crank & cam sensors should not really be affected by moisture unless the housings are cracked/damaged (pretty rare) Do you have a CEL on? (does it even work?) If so, finding out what the code is would be big help in diagnosing. Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 7, 2013 Share Posted October 7, 2013 I had a similar problem with my 96 years ago and it was water getting into the MAF. I replaced the MAF and put the sound deadeners back in and it never happened again. Quote Link to comment Share on other sites More sharing options...
later_Peter Posted October 7, 2013 Share Posted October 7, 2013 I had this problem (a while back) with a Datsun PickUp Truck... spark plug wires. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 9, 2013 Share Posted October 9, 2013 Spark plugs + wires or maybe a Cam Position sensor. All 3 are easy to swap out to check. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 9, 2013 Share Posted October 9, 2013 You can actually take a hose with a light mist and work your way around the engine compartment. Also do it UNDER the engine too kaing sure to get the engine temp sensor wire, and the cam and crank position wires Quote Link to comment Share on other sites More sharing options...
ivans imports Posted October 9, 2013 Share Posted October 9, 2013 Wire harness beside the battery in the fender well about 4 inch from fuse box is my gess broken or coroded wire Quote Link to comment Share on other sites More sharing options...
