dalton Posted October 22, 2013 Share Posted October 22, 2013 I just installed a Subaru 2.5L out of a Legacy in my Baja bug. it seem that the rev limiter is set to 4200rpms is there any way to raise it up to around 6000 rpms ? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 22, 2013 Share Posted October 22, 2013 It will need to see a vss signal. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted October 22, 2013 Share Posted October 22, 2013 +1 speed senser needs imput try a inline speed senser mabee find one on 90s ford thats inline Quote Link to comment Share on other sites More sharing options...
dalton Posted October 22, 2013 Author Share Posted October 22, 2013 I can do that. what pin on the computer is the VSS? does anyone have a copy of the pin out? Dalton Quote Link to comment Share on other sites More sharing options...
dalton Posted October 22, 2013 Author Share Posted October 22, 2013 this is my first drive with it... Love the power. Quote Link to comment Share on other sites More sharing options...
dalton Posted October 22, 2013 Author Share Posted October 22, 2013 the computer came out of a 1999 Outback Legacy with an auto tranny. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 23, 2013 Share Posted October 23, 2013 That rev limiter you are hitting is "limp mode". A lack of a VSS signal will put the car in limp mode. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 23, 2013 Share Posted October 23, 2013 There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch. Quote Link to comment Share on other sites More sharing options...
dalton Posted October 23, 2013 Author Share Posted October 23, 2013 There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch. does anyone have the ECU pin out? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 23, 2013 Share Posted October 23, 2013 You can find the FSM for 99 here: http://www.main.experiencetherave.com/subaru_manual_scans/ Look in the wiring diagram section. ECU pinout should be in there. If not there look in OBD2 diagnostics under troubleshooting. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted October 23, 2013 Share Posted October 23, 2013 Nice rig....Does the radiator function well at its present location?? IMO, it looks a bit awkward where it is mounted. You would get better air flow if you swapped radiator and spare tire mounting locations. Something to think about. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted October 23, 2013 Share Posted October 23, 2013 Very nice job !!! a 90-92 wire harness from legacy will run that engine and needs no vss to run i use this harness becuse is non obd2 and has no limp mode makes better power to. You may want to think about that harness have had many problems trying to stand alone 95 and up harneses Quote Link to comment Share on other sites More sharing options...
dalton Posted October 23, 2013 Author Share Posted October 23, 2013 Nice rig....Does the radiator function well at its present location?? IMO, it looks a bit awkward where it is mounted. You would get better air flow if you swapped radiator and spare tire mounting locations. Something to think about. the radiator seems to work fine. it does 80mph all day long. I wanted to keep the weight down low. 1 Quote Link to comment Share on other sites More sharing options...
dalton Posted October 23, 2013 Author Share Posted October 23, 2013 There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch. does anyone know what pin needs to be grounded? Quote Link to comment Share on other sites More sharing options...
dalton Posted October 23, 2013 Author Share Posted October 23, 2013 Thanks for the help guys.. Quote Link to comment Share on other sites More sharing options...
