99lego Posted November 7, 2013 Share Posted November 7, 2013 Hey all! I've been poking around the site searching for info on 6-Speed swap. I'm trying to find out who has paired a 6-Speed to their EJ motors and what all it entailed. In the mean time... 1 Quote Link to comment Share on other sites More sharing options...
99lego Posted November 7, 2013 Author Share Posted November 7, 2013 With a 3.9 final drive it seems the most logical way to do this would be find a donor '04 STi (5x100 hubs) and gearbox. Unclear on what driveshaft is going to work with this. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 7, 2013 Share Posted November 7, 2013 I had one in my 04 Forester XT. Loved it. Quote Link to comment Share on other sites More sharing options...
99lego Posted November 7, 2013 Author Share Posted November 7, 2013 I had one in my 04 Forester XT. Loved it. ^ So what all was involved with getting that in? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 7, 2013 Share Posted November 7, 2013 ^ So what all was involved with getting that in? It bolted right up. You can even use a 5spd clutch and flywheel if you need to. In a Forester, it requires you to use a Forester automatic driveshaft, unless you remove the factory lift, then you can use an STi sriveshaft and tranny crossmember. If you use the Forester driveshaft, and you change to an STi R180 rear diff, you need to change the pinion flange on the rear diff. Front hubs are the same, so you can use Forester or Impreza front axles. The rear hubs are different if you go with an R180, so you need STi rear hubs, and axles. Or you can use an older R160 with the same final drive as the transmission, and use the Forester rear hubs, and axles to match the diff. 1 Quote Link to comment Share on other sites More sharing options...
99lego Posted November 8, 2013 Author Share Posted November 8, 2013 It bolted right up. You can even use a 5spd clutch and flywheel if you need to. In a Forester, it requires you to use a Forester automatic driveshaft, unless you remove the factory lift, then you can use an STi sriveshaft and tranny crossmember. If you use the Forester driveshaft, and you change to an STi R180 rear diff, you need to change the pinion flange on the rear diff. Front hubs are the same, so you can use Forester or Impreza front axles. The rear hubs are different if you go with an R180, so you need STi rear hubs, and axles. Or you can use an older R160 with the same final drive as the transmission, and use the Forester rear hubs, and axles to match the diff. ^ Great info for Forester / Imp platorms! Thanks! Anyone care to chime in with info for Leg / OB platforms? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 18, 2013 Share Posted November 18, 2013 Here's the info from my 6spd swap into my 1st gen Legacy. http://bbs.legacycentral.org/viewtopic.php?f=7&t=49917 1 Quote Link to comment Share on other sites More sharing options...
99lego Posted November 22, 2013 Author Share Posted November 22, 2013 Here's the info from my 6spd swap into my 1st gen Legacy. http://bbs.legacycentral.org/viewtopic.php?f=7&t=49917 Stellar write up! Still looking for others out there who've done this, or are planning to do one. Quote Link to comment Share on other sites More sharing options...
