Scrub2k Posted April 26, 2004 Share Posted April 26, 2004 Ok i finally got around to making a key for this DL that ive got now, and i tried to start it and it turns over and eveything fine but it wont start, it sounds like its just spinning the motor, with no compression or anything but i pulled off the distributor cap and the rotor is still spinning and i pulled of the passenger side T-Belt cover and the belt is still intact and spinning, so i dont think its the Timing Belts. Any Ideas on what it could be??? PS: I even tried a little bit of Starting Fluid to see if it would fire up at all, and still nothing. Edit: BTW its a 88 DL Wagon Spfi Quote Link to comment Share on other sites More sharing options...
baccaruda Posted April 27, 2004 Share Posted April 27, 2004 did you change the timing belts? if so, confirm that you put them on correctly. have you had the distributor out? make sure it's in properly. it sounds like you are missing spark. check to see that you're getting that. double check everything you've worked on since the last time the car was running. Quote Link to comment Share on other sites More sharing options...
Scrub2k Posted April 27, 2004 Author Share Posted April 27, 2004 Well i have never seen the car run, i got it for Free, and am now trying to get it to run so i have a second car to drive. how do i check to see if the timing belt is correct? Quote Link to comment Share on other sites More sharing options...
