808Legacy Posted December 5, 2013 Share Posted December 5, 2013 Squeals loud on "cold" starts not after. "Cold" is not really cold here in Hawaii, just first thing in am (never below 70deg.) Belts seem good and tight (and in good condition); tried the soap trick. Maybe it's a pulley tensioner? Doesn't squeal after warmed up. Any ideas? Mahalo in advance! Quote Link to comment Share on other sites More sharing options...
Olnick Posted December 5, 2013 Share Posted December 5, 2013 Hey 808--maybe it's just an island thing! I had the same problem here in Honolulu awhile back. Finally took the AC belt tensioner out to check the idler pulley--thought the bearing had failed. Turned out that the mounting nut was a bit loose and for a short time at start-up the pulley would go kapakahi--it was "off-axis," not perpendicular to the belt. Reinstalled the mechanism, adjusted the tension, tightened the mounting nut and it's been quiet ever since. Good luck. Aloha. Quote Link to comment Share on other sites More sharing options...
808Legacy Posted December 5, 2013 Author Share Posted December 5, 2013 (edited) Excellent, I'll check that tomorrow. See if it kapakahi. Mahalo from Maui! Edited December 5, 2013 by 808Legacy Quote Link to comment Share on other sites More sharing options...
