roxtar Posted April 28, 2004 Share Posted April 28, 2004 ok. I've gotten my error codes to disappear but i still have my major problem of the engine bucking like mad under just about any degree of load (including just stomping the pedal in neutral) i've replaced the fuel filter in the engine compartment already. My question is whether or not there is a second filter in the rear of the car by the fuel tank. also, is there a strainer for the fuel pump? (have been unable to locate the part on any of the parts websites) Is the strainer maybe built right into the fuel pump? also, could the fact that i need to replace my water pump be causing this behavior? Quote Link to comment Share on other sites More sharing options...
Partsman Posted April 28, 2004 Share Posted April 28, 2004 Should be some sort of strainer in the tank - never seen a part number aftermarket. No second filter. BTW, anyone know how/where to check fuel pressure? I have almost the same problem developing, but mine only happens at 3/4 tank and below, so I think there's a problem with the pump pulling prime. Roxtar, didn't mean to hijack your post - I think you need to check your pressure as well. Quote Link to comment Share on other sites More sharing options...
roxtar Posted April 28, 2004 Author Share Posted April 28, 2004 need more help...BUMP Quote Link to comment Share on other sites More sharing options...
roxtar Posted April 29, 2004 Author Share Posted April 29, 2004 and.... rebump. any ideas? Quote Link to comment Share on other sites More sharing options...
86subaru Posted April 29, 2004 Share Posted April 29, 2004 this may or may not help, but i had a fuel leak on my 88 spfi gl 4wd wagon, it was the fuel damper which is right at the fuel pump, about the size of a quarter and fatter , i was told is is like a check valve ,and to put 1 back in it's place , Quote Link to comment Share on other sites More sharing options...
