A friend has a 2001 Outback vdc.
The heater blower stopped blowing.
It will not blow on any speed.
I found  fuses behind the change door to the left of the steering wheel, in addition to the fuse box under the hood.
All fuses were good.
Can anyone tell me where exactly is the blower relay on the 2001 Outback VDC?
Thanks
monk in NC
In case you aren't aware of it, the resistor pack is on the return side of the circuit. Check to see if power is getting to the motor while the selector switch is set to full speed. If you do see power you should be able to ground the return side of the motor and make it run and verify the motor is okay. It would also mean the relay is okay.
