monk50 Posted January 14, 2014 Share Posted January 14, 2014 A friend has a 2001 Outback vdc. The heater blower stopped blowing. It will not blow on any speed. I found fuses behind the change door to the left of the steering wheel, in addition to the fuse box under the hood. All fuses were good. Can anyone tell me where exactly is the blower relay on the 2001 Outback VDC? Thanks monk in NC Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 14, 2014 Share Posted January 14, 2014 I think it is located in the far left side of the dash area but not positive of that. You might try running power directly to the motor to verify it is okay if you haven't done that already. Quote Link to comment Share on other sites More sharing options...
monk50 Posted January 14, 2014 Author Share Posted January 14, 2014 Thanks. If anyone know specifically where the relay is located I would appreciate the help. Thanks Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 15, 2014 Share Posted January 15, 2014 In case you aren't aware of it, the resistor pack is on the return side of the circuit. Check to see if power is getting to the motor while the selector switch is set to full speed. If you do see power you should be able to ground the return side of the motor and make it run and verify the motor is okay. It would also mean the relay is okay. Quote Link to comment Share on other sites More sharing options...
monk50 Posted January 15, 2014 Author Share Posted January 15, 2014 (edited) Thanks, will check. All good suggestions and greatly appreciated. Monk Still hunting for the relay location. Thanks Edited January 15, 2014 by monk50 Quote Link to comment Share on other sites More sharing options...
