88 Wagon drive shaft info
9945
you can try a junk yard.  any loyale wagon with the same trans should fit.  find a local driveline shop, or machine shop and they can probably build you a 1 piece for around $100.  theres a lot on these drivelines that aren't supposed to be repairable so replacement is the easiest option.
The rear part of the 2 piece driveshaft is the same between automatic and manual trans for 85-89 GL, DL, RX, 90-94 Loyale, and 85-92 XT.
The u-joints are staked in, a toyota part number is compatible. Anyone experienced with toyota or nissan driveshafts should be able to do the work.
Any idea of the part # or what nissan or toyota to look for to get the ujoint
