hippy62378 Posted January 31, 2014 Share Posted January 31, 2014 (edited) I have a 1996 legacy ls wagon 2.2 auto. the other day it went into a limp mode. and when we shut it off it wouldn't start. we had the codes ran and no codes the coil pack was rotted and grounding out on its mounting bolts. we replaced the coil pack, and it still didn't start. I have checked that it is getting spark at the plug and it was great. then I went through the fuel pump, relay and filter. the fuel system works past the fuel filter the injectors are getting power. I am so lost. please help Edited January 31, 2014 by hippy62378 Quote Link to comment Share on other sites More sharing options...
snofool Posted January 31, 2014 Share Posted January 31, 2014 check all connections, airflow, vacuums,If mass air sensor is out or unplugged it won't start. Clean battery terminals and attachment points. Does it crank over? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 31, 2014 Share Posted January 31, 2014 Try holding the gas pedal on the floor for a few seconds while cranking then release it. If it starts its getting too much fuel and flooding. Could also have jumped timing. Quote Link to comment Share on other sites More sharing options...
hippy62378 Posted January 31, 2014 Author Share Posted January 31, 2014 the timing is right on I have checked that and it was also replaced a month ago when I did the water pump it cranks just fine no dragging or anything and there is spark and fuel after the filter it ran fine all the way up to Colorado springs from canon city and that's a bout 40 miles then we parked the car came out hours later and it started just fine then when we got about a block it started doin this stuff and we changed the coil pack and that was it crank but no start I went through all of the fuel system except the injectors but I did check that they are getting power Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 31, 2014 Share Posted January 31, 2014 maybe crank or cam position sensor? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 31, 2014 Share Posted January 31, 2014 I would check the timing anyway. The tensioner could have gone bad and let the belt go slack. Quote Link to comment Share on other sites More sharing options...
