Sdam87 Posted February 15, 2014 Share Posted February 15, 2014 Hey, Hows it goin? Sam here, Bought me a 92 loyale wagon today. Second one I've ever owned. (First one was when I was in high school) Figured I'd say hey. So, Hey! haha 2 Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 15, 2014 Share Posted February 15, 2014 Looks like my car when it was stock, what are the plans for her? Quote Link to comment Share on other sites More sharing options...
Sdam87 Posted February 15, 2014 Author Share Posted February 15, 2014 Well.. First thing Im gonna do is a full blown tune up and fix a couple rust holes and the rat (it leaks a bit), maybe find some stock alloy rims for it. Probably go up with it. Once I figure out how that is done. haha Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 17, 2014 Share Posted February 17, 2014 Well you came to the right place for questions if you need help, I think you just just do a full blown EJ Swap, 6" lift, drilled hubs and bigger tires I mean seriously it only involves lots of time and money bro! Quote Link to comment Share on other sites More sharing options...
Sdam87 Posted February 18, 2014 Author Share Posted February 18, 2014 Lol no 6 inch lift. If anything maybe a half inch to a inch strut spacer. Gonna drill the hubs for sure. haha Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 19, 2014 Share Posted February 19, 2014 A half inch??? Whats the point? Haha. If you drill your hubs out to 6 lug, pound out two of the studs then put a 6 lug wheel on the remaining two studs and put your lug nuts on and tighten em down. Now mark the remaining holes to be drilled, take it apart drill out your holes, I just used a 9/16 drill bit you can find the right bit to be able to pound on the stud if you want. After they are drilled and if you decide to use the bigger bit and weld the backs of the studs put your wheel back on and tighten the two previous lug nuts. Now put the other 4 lugs through and put lug nuts on them and tighten them. Now weld the backs of the studs and this will insure the studs are lined up perfectly. See I didn't do it this way and had to bang the studs around on the car which led to a wheel bearing failing because I was in a rush. Lessons learned. Quote Link to comment Share on other sites More sharing options...
Sdam87 Posted February 19, 2014 Author Share Posted February 19, 2014 Well, half inch or a inch.. I dont wanna throw the suspension out of wack/looking to be crazy with it.. But crazy can be cool.. Soo idk yet. haha Quote Link to comment Share on other sites More sharing options...
Mundog64 Posted February 21, 2014 Share Posted February 21, 2014 Welcome. Nice looking wagon. 1 Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted February 21, 2014 Share Posted February 21, 2014 Your best bet is a 2" lift, dont have to throw the suspension out of whack, dont even have to extend the steering, but you can fit slightly larger tires which will give you even more ground clearance and it honestly looks stock Or just bigger tires... EVERYONE says my car looks lifted... stock 185/70/13 tires upgraded to 205/60/15 (so not MUCH bigger) but the bigger wheels and tires give it a lifted appearance. Quote Link to comment Share on other sites More sharing options...
Sdam87 Posted February 23, 2014 Author Share Posted February 23, 2014 So.. is your car lifted? (rugby) Do those 205's rub at all? (If its not lifted) Where could I find that 2" lift? Quote Link to comment Share on other sites More sharing options...
