The Scooby Posted May 3, 2004 Share Posted May 3, 2004 well my girlfriend just pointed this out a lil while ago, i have no reverse lights on my 86 GL wagon, 5sp d/r i swapped bulbs to no effect, is it the switch on the shifter/trans, or wiring?? Thanks, Shean Quote Link to comment Share on other sites More sharing options...
northguy Posted May 3, 2004 Share Posted May 3, 2004 Did you check the ground wire? Quote Link to comment Share on other sites More sharing options...
Cougar Posted May 3, 2004 Share Posted May 3, 2004 I would first check for the switch at the shift lever. If it isn't there, then check the tranny. Quote Link to comment Share on other sites More sharing options...
calebz Posted May 3, 2004 Share Posted May 3, 2004 No switch on the shifter on a 5 speed.. its in the tranny... get a multimeter and a wiring diagram and get to work. Quote Link to comment Share on other sites More sharing options...
