nipper Posted April 18, 2014 Share Posted April 18, 2014 Since this is SOHC engine I will be doing this timing belt myself. Blu was a DOHC so I was more then happy to pay someone to do it. I am looking on ebay and do not see many complete TB Kits (with seals or is that not the norm). Any recommendations? Also anyone have luck with buying new front hubs on ebay/ The "big car" (considering his lil brother is a Justy) is coming up on 200K and I would like to get ahead on somethings (read I have the money). I have an odd whining noise in the front just starting and I suspect a wheel hub. Thanks. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 18, 2014 Share Posted April 18, 2014 (edited) Amazon and rockauto are becoming far better shopping places for Subaru timing kits. Get the Gates kits for $110 here: http://www.amazon.com/Gates-TCK304-Timing-Belt-Component/dp/compatibility-chart/B002R8HMAY make sure this is the right water pump (one outlet instead of two should be correct): http://www.amazon.com/Gates-TCKWP307-Engine-Timing-Water/dp/compatibility-chart/B003TUCFT2 I always do water pump, cam seals, oil pump reseal while i'm in there but those components are robust enough to skip without much issue if one wants to/there's a compelling reason. I'm sure you know but don't use aftermarket water pump gaskets. The bolt on hubs are really easy to replace, assuming it's not rust-welded into place. 2005 should be new enough that issue is unlikely! Edited April 18, 2014 by grossgary Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 18, 2014 Share Posted April 18, 2014 Seals are cheap enough from a dealer. If you can't find a good kit with seals just get the seals separate rather than going cheap on the major parts just to get a kit with seals included. Whining isn't typically a wheel bearing issue. This is also not something I would cheap-out on if the bearings have to be pressed in. Rear bearings are bolt-on for that year so are easier to replace if a cheaper part doesn't last. Quote Link to comment Share on other sites More sharing options...
nipper Posted April 18, 2014 Author Share Posted April 18, 2014 i know its not a diff as the oil isnt clean, volume doesnt change with speed, and it does vary with suspension load. If I go over a dip in the road at 60 it will change in intensity as the suspension unloads. Quote Link to comment Share on other sites More sharing options...
