rico suave Posted June 28, 2014 Share Posted June 28, 2014 Hello Everyone I have owned my Baja for 2 years now with no significant problems. I have kept it well maintained, changing everything needed. As of late it started smoking from the exhaust and under the hood beneath the turbo where I think the manifold is...I took it to my mechanic ( whom I trust ). He told me that A. he thought it was the turbo going, and B. it needed a valve cover gasket. He said he wanted me to get a 2 nd opinion because the turbo is a big job. So I took it to another place where they have a Subaru mechanic and he said that he saw no indication of turbo issues. I then took it back to my mechanic. He changed the valve cover gasket. It still smoked. So I took it back again, and he said that there was something adjacent or behind the valve cover gasket and he fixed that. He told me to drive it for a week to see if the oil would burn off and if not bring it back... It is still smoking...maybe not as much...I am not quite sure yet. Today I took it about 45 miles and it didnt smoke until I was 1/2 mile from home. I am beside myself. NO loss of oil, always full, no idiot light...nothing... Any feedback is greatly appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
john in KY Posted June 28, 2014 Share Posted June 28, 2014 Did anyone check the CV boot under the turbo and I seem to recall the turbo has some sort of problem pertaining to a clogged return oil screen. Quote Link to comment Share on other sites More sharing options...
rico suave Posted June 28, 2014 Author Share Posted June 28, 2014 Thank you John, I will bring this to the attention of my mechanic. I appreciate your response. I don't know if he did or not, I am assuming not. I hate to change the turbo if it isn't that...I will keep you posted when I ask him next week. thanks, Kelly Quote Link to comment Share on other sites More sharing options...
rico suave Posted June 28, 2014 Author Share Posted June 28, 2014 But I do know that it is leaking oil beneath the turbo, a small gathering of oil in the shield maybe??? Not sure what it is called. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 28, 2014 Share Posted June 28, 2014 There is a banjo bolt for the oil supply line on the turbo that can loosen and leak oil. It's recommended to remove the banjo bolt, install new copper washers and make sure the small screen filter in the banjo bolt is clean before re-installing. There is also a known issue with one of the oil lines running to the turbo. Subaru has a TSB about it. I don't recall if it was the supply line or the drain line that had the issue. Quote Link to comment Share on other sites More sharing options...
rico suave Posted June 28, 2014 Author Share Posted June 28, 2014 Thank you, I am aware of that banjo bolt. But will discuss in depth with mechanic...Appreciate your feedback ! Quote Link to comment Share on other sites More sharing options...
baja Posted August 22, 2014 Share Posted August 22, 2014 Mine was smoking a little wile ago and it was the cv axle the boot cracked and flung grease onto the turbo took me two attempts to steam it off at the car wash lol Quote Link to comment Share on other sites More sharing options...
rico suave Posted August 22, 2014 Author Share Posted August 22, 2014 I ended up changing the turbo. It has been running fine since. Quote Link to comment Share on other sites More sharing options...
