sub1980s Posted December 4, 2015 Author Share Posted December 4, 2015 rf guard Quote Link to comment Share on other sites More sharing options...
Tom0 Posted December 4, 2015 Share Posted December 4, 2015 There's a guy wrecking a few old leones up your wayhttp://www.trademe.co.nz/Browse/Listing.aspx?id=992273419Not sure if any of it might be of use to you. He was good to deal with. Wish I had the room and skills you're displaying haha. Keep up the great work Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 5, 2015 Author Share Posted December 5, 2015 Was going get the engine for internal bits,cosmetic stuff if useable,decided not to,no room. like the leone wagon pic you have,had a sedan while ago. Thanks for heads up.. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 sanding down the body from windscreen to back of car,reseal seam joins as removed old stuff from repairs,stone chip sills,rocker panels, as my filler lines wonky on bottom,stone chip disguises it,as did not want to go back and redo,sill edge was damaged and dented from 4wdriving or jacking the car on it in places,quite soft,block sand some funny bits,wonky lines and slightly under filled bits. redo bits wasn't happy with,and use green scotch pad on fiddley bits. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 oops double posts ,please remove them.black stone chip on sills. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 redo filler work Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 repaired rear 1/4 panel 8months ago,now the small area fixed, rear quarter accident damage, filler work poorly done shape wise,ground filler out and redo,filler covers just about the whole 1/4 panel,not much else you can do with it. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 block sanding p240 Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 more sanding Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 3 wet coats of primer ,4 on outside parts Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 hopefully enough primer on for wetsanding ,or spot prime? Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 19, 2015 Author Share Posted December 19, 2015 guide coat black Quote Link to comment Share on other sites More sharing options...
subnz Posted December 20, 2015 Share Posted December 20, 2015 (edited) Hi from the deep south Nice example and work, These were terrible for rust here along with Brumby (brat) in 70s 80s models. One of these similar was my 1st Subaru 23 to 20 years ago 83 EA81 wagon 4MT D/R unfortunately don't have any digital pix of it.. Still have an 87 Brumby EA81 4MT D/R in good original condition, was my late fathers (from Alexandra so body really good) see pix link below Edited December 20, 2015 by subnz Quote Link to comment Share on other sites More sharing options...
sub1980s Posted December 21, 2015 Author Share Posted December 21, 2015 Hi, Nice Brumby (brat) most are knocked around or age related problems.Rust was bad on them.was keen on a ute not much room to push the seat back.nice subarus cheers for comments. 1 Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 7, 2016 Author Share Posted February 7, 2016 sanding primer on inside areas, fine scotch pad or p500 sanding pads fro from DA sander.forgot to take pictures of sanded areas, so no before shot. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 7, 2016 Author Share Posted February 7, 2016 basecoat and clearcoat on,done at home the painting, engine and front guards next.Trying to get a day that's not winding or wind blowing in to garage, I did wet the floor before spraying,careful not flick water off air hose onto job.Once inside work painted, bolt on panels,and sand outside , and paint outside. Quote Link to comment Share on other sites More sharing options...
Toolbox35 Posted February 8, 2016 Share Posted February 8, 2016 Nice work Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 more progress,the prep goes on,inside paint work from firewall to front of car. bonnet Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 inside paint on front guards. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 id tag and front guard bits. front cowl. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 colour different in photos,from the lighting,you sure wonder sometimes why i did start it,its a lot of work.heres some pics. Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 before and after Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 after Quote Link to comment Share on other sites More sharing options...
sub1980s Posted February 13, 2016 Author Share Posted February 13, 2016 if only I had a engine,plenty more to do on it,later. Quote Link to comment Share on other sites More sharing options...
KiwiGL Posted February 16, 2016 Share Posted February 16, 2016 Love it, looks great. Is that the original colour? Quote Link to comment Share on other sites More sharing options...
