killaman Posted October 12, 2014 Share Posted October 12, 2014 I have an 87 gl-10 turbo that has recently sprung quite a large coolant leak (it come pouring right of the engine as I pot coolant into it). I have looked under the hood and underneath the car and I think that the coolant is leaking from the water pump. Is there anywhere else that it could be cause it to leak so much coolant and is there any advice that you could give me on how to fix it. I have basic automotive knowledge but if I could get some pointers and maybe simple instructions I know I can at least attempt to fix it. 1 Quote Link to comment Share on other sites More sharing options...
TomRhere Posted October 12, 2014 Share Posted October 12, 2014 Water pump has weep holes in the housing that will let coolant out if the shaft seal fails. Feed tube to water pump has an O-ring where it fits to pump housing. Short 90* hose on the top of the water pump for the heater core line. Quote Link to comment Share on other sites More sharing options...
MR_Loyale Posted October 12, 2014 Share Posted October 12, 2014 Park the car and start the engine. Open the hood and manually rev the engine by manipulating the throttle cable. Give it a good high sustained rev to force any leak. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 12, 2014 Share Posted October 12, 2014 Where is it coming out? the front? the side, which side? underneath? Quote Link to comment Share on other sites More sharing options...
killaman Posted October 12, 2014 Author Share Posted October 12, 2014 (edited) Where is it coming out? the front? the side, which side? underneath? It is coming out from underneath the car Edited October 12, 2014 by killaman Quote Link to comment Share on other sites More sharing options...
killaman Posted October 12, 2014 Author Share Posted October 12, 2014 (edited) Water pump has weep holes in the housing that will let coolant out if the shaft seal fails. Feed tube to water pump has an O-ring where it fits to pump housing. Short 90* hose on the top of the water pump for the heater core line. ok im pretty new to cars so how would I do this? Edited October 12, 2014 by killaman Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 12, 2014 Share Posted October 12, 2014 It is coming out from underneath the car DUH!!! I meant front/side/underneath of engine.....where on the engine is the coolant coming from............Gravity applies everywhere so OF COURSE it's gonna be under the car. If you can't figure that out maybe you shouldn't be worrying about try to diagnos it yourself....since you have no chance of fixing it yourself......Close your hood.........take it to a mechanic or at least someone knowledgable about what parts an engine has. Quote Link to comment Share on other sites More sharing options...
killaman Posted October 12, 2014 Author Share Posted October 12, 2014 (edited) DUH!!! I meant front/side/underneath of engine.....where on the engine is the coolant coming from............Gravity applies everywhere so OF COURSE it's gonna be under the car. If you can't figure that out maybe you shouldn't be worrying about try to diagnos it yourself....since you have no chance of fixing it yourself......Close your hood.........take it to a mechanic or at least someone knowledgable about what parts an engine has. I would've already taken it to a mechanic if I could afford it but I don't have the money to do that. It is coming from the front of the engine. Edited October 12, 2014 by killaman Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 12, 2014 Share Posted October 12, 2014 I would've already taken it to a mechanic if I could afford it but I don't have the money to do that. It is coming from the front of the engine. I don't have enough money to see a dentist but that doensn't mean I'm gonna start pulling my own teeth. Quote Link to comment Share on other sites More sharing options...
MR_Loyale Posted October 12, 2014 Share Posted October 12, 2014 I don't have enough money to see a dentist but that doensn't mean I'm gonna start pulling my own teeth. Me neither. I just go into a bar, find the biggest baddest dude and insult him. Then he knocks those bad teeth out for nothin. Quote Link to comment Share on other sites More sharing options...
Tommy1b Posted October 13, 2014 Share Posted October 13, 2014 Maybe this is your problem ... Quote Link to comment Share on other sites More sharing options...
Tommy1b Posted October 13, 2014 Share Posted October 13, 2014 Or This ..... Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted October 13, 2014 Share Posted October 13, 2014 In addition to the above suggestions, check your lower radiator hose, it connects directly below the radiator cap. There is the aforementioned steel pipe that runs between that hose and the water pump. Make sure that isn't cracked or broken when you're testing the lower radiator hose. There is a little elbow that jumps off the water pump and runs up the block under the intake (that big aluminum piece on top of the engine). Check that little guy for any leaking as well. Hopefully you can figure out the issue easily Twitch PS: I apologize for any rudeness you may have encountered here, most members are usually pretty civil. Quote Link to comment Share on other sites More sharing options...
killaman Posted October 13, 2014 Author Share Posted October 13, 2014 In addition to the above suggestions, check your lower radiator hose, it connects directly below the radiator cap. There is the aforementioned steel pipe that runs between that hose and the water pump. Make sure that isn't cracked or broken when you're testing the lower radiator hose. There is a little elbow that jumps off the water pump and runs up the block under the intake (that big aluminum piece on top of the engine). Check that little guy for any leaking as well. Hopefully you can figure out the issue easily Twitch PS: I apologize for any rudeness you may have encountered here, most members are usually pretty civil. Thanks for the help , so the lower radiator hose own forking fine the leak is past it where it goes into the engine block and it leaks from there. I looked at all of the hoses and pipes but there is no leakage coming from them, what would you recommend next? Quote Link to comment Share on other sites More sharing options...
