6 Star Posted October 13, 2014 Share Posted October 13, 2014 1986 GL Wagon Stock carbureted ea82 For some reason the car is extremely hard to start, and once it is started, will not idle unless if throttle is added.Removing throttle will kill the engine soon if not immediately right after removal. Previous symptoms while car was being driven: engine missing at idle speed engine missing throughout rpm range while driving (mostly low rpm) engine randomly would die at idle while taking a right turn in neutral, engine would stall taking off from a stop or from a slow roll (shifting to 2nd around a corner) it would sometimes just fall flat on its face and chug very slowly as if it was about to die. feathering the throttle afterwards for a few seconds would then bring the rpm back up. Idle speed is set at about 1,100rpm (set there because it was not idling right and would die) timing is correct distributor is advanced to the end of its adjustment range, changing position doesn't do much if anything When starting the car, when the key is turned to the "on" position, I cannot hear the fuel pump priming itself or the relay/ controller clicking. On a Loyale that I own, when first turned to the "on" position I hear a clicking from a relay, and I hear the fuel pump priming from the rear of the car. This does not happen on the '86. Is it just that the two are designed differently? One is carbed, the other FI... Quote Link to comment Share on other sites More sharing options...
robm Posted October 14, 2014 Share Posted October 14, 2014 I am no expert on the carbs on these cars, but if it has a fuel cut solenoid, I would check to make sure it was coming on. Quote Link to comment Share on other sites More sharing options...
BirdMobile Posted October 14, 2014 Share Posted October 14, 2014 (edited) Check your fuel filters. Edited October 14, 2014 by BirdMobile Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 15, 2014 Share Posted October 15, 2014 Ditto about filters. Also, have you checked all your vacuum lines are plugged in/unbroken? And, yes your 2 cars are designed differently. The carb fuel pump can't even think about supplying enough fuel for an injected system. Quote Link to comment Share on other sites More sharing options...
6 Star Posted November 6, 2014 Author Share Posted November 6, 2014 This problem was resolved, check it out here: http://www.ultimatesubaru.org/forum/topic/128701-the-86-wagon/page-2 Quote Link to comment Share on other sites More sharing options...
