comatosellama Posted November 4, 2014 Share Posted November 4, 2014 Could I just throw on some washers and longer bolts for the trailing arm bracket drop? Or should I go get the read deal, or make some spacers from 2x1ish steel tubing. Thanks- CL Quote Link to comment Share on other sites More sharing options...
lmdew Posted November 4, 2014 Share Posted November 4, 2014 Washers only will add some shear load. I'd get a plate built to drop on top. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted November 4, 2014 Author Share Posted November 4, 2014 Washers only will add some shear load. I'd get a plate built to drop on top. What do you mean by plate built to drop on top? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted November 4, 2014 Share Posted November 4, 2014 Grab a set of trailing arm mounts from a 96-99 outback. The geometry of them will also push the wheel back to center of the wheelwell. 1 Quote Link to comment Share on other sites More sharing options...
