espey_16 Posted December 30, 2014 Share Posted December 30, 2014 I was adding some tube to my rear bumper this weekend and noticed it was a little loose. I pulled the plugs in the hatch so I could tighten it up and saw that the driver side mounting holes are ripped on the body. What would be the best plan of attack for repairing this problem? Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 30, 2014 Share Posted December 30, 2014 Plating both sides and tying into existing body parts around them. Only thing you can do usually, at least to maintain any type of strength. cheers Quote Link to comment Share on other sites More sharing options...
espey_16 Posted December 31, 2014 Author Share Posted December 31, 2014 Ok. I was thinking about putting a 1/4" plate of steel in the middle hatch, and another on the bottom of the car, and bolting those together. The bottom plate will be welded to the bumper. I would think with 6-8 bolts in the plates in the hatch, I'd have more strength than the original mounting points. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted January 1, 2015 Share Posted January 1, 2015 1/8" steel would be far stronger than the original steel.There is nothing you can do with a subaru that would require 1/4" plates sand witched together.This is a 2500lb car not a 8k pound super duty. Quote Link to comment Share on other sites More sharing options...
espey_16 Posted January 2, 2015 Author Share Posted January 2, 2015 I'm pretty good at breaking and bending stuff. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 2, 2015 Share Posted January 2, 2015 Unfortunately , I agree with uberoo. But the only reason would be that it would impede on welding the two together. WElding thinner stackedd sheet to plate sucks, and unless you have lots of practice is very difficult. Short circuit welding is about the only option here once you have the right settings. I think that 12ga or 1/8th would be sufficient. However, If it is just a bolt affair, make sure you chamfer the corners of the steel so that hard edges are not wanting to poke holes through the under carriage.Round your corners as well. cheers Quote Link to comment Share on other sites More sharing options...
espey_16 Posted January 2, 2015 Author Share Posted January 2, 2015 Yeah, that's kinda what I was thinking too. If I pulled something or backed into something I don't want the plates trying to rip through the body. Quote Link to comment Share on other sites More sharing options...
