5 lug swap on 85 gl HELP!
So I'm planning on doing a ej22 swap in my wagon but there's a lot of things i need to plan out before I can do so. One of those things being how am I going to do a 5 lug swap so i can have a better suspension system in my gl, have easier and cheaper access to wheels, and also be able to lower it easier.
So here is my question for you guys:
Is it possible to put 95 legacy suspension in my gl and if so, how do I do it?
  • Like 1
Welcome! This has been covered hundreds if not thousands of times here. There are stickies, writeups, build threads, etc. There are probably a dozen specific ways to do it.
Short version is, most of the front will work, almost none of the rear will without EXTREME fabrication. You will need 4WD XT6 rear hubs.
