Tye Posted July 9, 2015 Share Posted July 9, 2015 (edited) Hey y'all, about to do a EJ22 swap into my Loyale,with the EA82 transmission. I have the re-drilled EA82 flywheel and i'm going to use the XT6 pressure plate and clutch disk(Correct?) my question is whether i should use the XT6 release bearing or an EA82 one? Edited July 9, 2015 by Tye Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted July 9, 2015 Share Posted July 9, 2015 I used a Sachs XT6 clutch kit with a machined XT6 flywheel when I did my swap. You should be able to use an XT6 pressure plate with an EA82 flywheel too. I would make sure to have the stepping machined to match the XT6 pressure plate when you get the flywheel turned. Quote Link to comment Share on other sites More sharing options...
El Presidente Posted July 9, 2015 Share Posted July 9, 2015 Have the flywheel machined to xt6 specs, thats where you get more clamp force.. The xt6 pressure plate and clutch disc is the same as the loyale now, so you can use your old ones if you want. You don't need a different throw out bearing either, just grind the flywheel..everything else can be ea82/loyale. Josh 1 Quote Link to comment Share on other sites More sharing options...
Tye Posted July 9, 2015 Author Share Posted July 9, 2015 thanks guys, helps alot 1 Quote Link to comment Share on other sites More sharing options...
