Tye Posted August 7, 2015 Share Posted August 7, 2015 okay so i have basically completed the ej swap, everything except the wiring. most the wiring is done but i cant get it to run. considering hiring somebody to troubleshoot. how much would somebody with ej wiring experience charge to come over and trouble shoot my wiring issues? I live in Woodinville thanks in advance Quote Link to comment Share on other sites More sharing options...
Tye Posted August 20, 2015 Author Share Posted August 20, 2015 bump Quote Link to comment Share on other sites More sharing options...
bratbro Posted August 20, 2015 Share Posted August 20, 2015 I don't know about the ej. But just basic trouble shooting I'll start with gas making sure the pump working then spark etc. Etc.. You have everything wire in? Might be your problem if it's not. Quote Link to comment Share on other sites More sharing options...
Tye Posted August 21, 2015 Author Share Posted August 21, 2015 I don't know about the ej. But just basic trouble shooting I'll start with gas making sure the pump working then spark etc. Etc.. You have everything wire in? Might be your problem if it's not. we have fuel but no spark Quote Link to comment Share on other sites More sharing options...
djellum Posted August 21, 2015 Share Posted August 21, 2015 double check your grounds for the ecm. I dont know specifics but if the ecm detects wonky grounds they wont activate on some of them. I heard of Nissans that had issues because the case for the ecm lost ground from rusty bolts, Quote Link to comment Share on other sites More sharing options...
bratbro Posted August 22, 2015 Share Posted August 22, 2015 Have you checked your fuses? Some times its that simple. Then I would pop the top on your disty check the cap for cracks, corrosion, fouling, and if the rotor is damaged. Do you have a shop manual? Quote Link to comment Share on other sites More sharing options...
