Jholt Posted August 24, 2015 Share Posted August 24, 2015 My legacy brighton doesn't have a tachometer. So I went to pick and pull and pulled a cluster out from another vehicle with a tachometer. I installed it and everything seemed to go okay until I drove home and had no speedometer. So I pulled my old speedometer out (thinking it was a loose connection in the back) and switched it with my new one. The speedo worked but now the tach did not. I'm wondering what the problem is with the wiring? Do I need to wire the tach through the speedo? Or should I try putting the tach in my old cluster? 1 Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted September 13, 2015 Share Posted September 13, 2015 Welcome to the USMB! I'm going to move your thread to the new gen forum where it should get some more visibility. Quote Link to comment Share on other sites More sharing options...
Jholt Posted September 18, 2015 Author Share Posted September 18, 2015 Thank you very much! May you please send me a link to the new discussion? Quote Link to comment Share on other sites More sharing options...
