mcnea001 Posted September 5, 2015 Share Posted September 5, 2015 All: Happy Labor Day! 1995 Subaru Legacy L / 186K / EJ22E Working my way down to the oil pump / cam seals removing items as I go. Have afew questions/problems and could use everyones help. 1) Crankshaft / Camshaft Alignment Marks. If you look at the attached pics when I set everything and removed thetiming belts. I have the Camshaft alignment marks correct....but theCrankshaft alignment mark was off. (Guy I purchased it from had donethe timing belt. Question: Should I leave it this way...or move the crank so the alignment mark is at the 12 position (vsthe 3pm position in the pic). I guess this did not cause a problemsince it is a non-interference motor? 2) I have removed the timing belt / crank shaft / but cannot break the bolts on the Camshaft pulleys free. Any good ideas out there? Thanks as always!!! Tom 1 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 6, 2015 Share Posted September 6, 2015 Crankshaft timing is corret. The timing mark is on the rear of the sprocket. Do not use arrows for timing. If timing were 90° off it wouldn't run at all. The cam sprocket bolts are very tight. Torque spec is around 60ftlbs IIRC. Put the old belt on the sprocket then wrap the belt around the crankshaft sprocket, pull it tight, and clamp it to itself with vice grips. That should hold the sprocket while you loosen the bolt. 1 Quote Link to comment Share on other sites More sharing options...
mikec03 Posted September 6, 2015 Share Posted September 6, 2015 You should read some of the DIY's or watch a few of the many you tubes on subaru timing belt changes. Here is a DIY for the 95 for example. http://lovehorsepower.com/joomla/index.php?option=com_content&view=article&id=48:1995-subaru-legacy-outback-timing-belt-and-water-pump-replacement&catid=10:subaru-legacy&Itemid=64 Quote Link to comment Share on other sites More sharing options...
mcnea001 Posted September 8, 2015 Author Share Posted September 8, 2015 Crankshaft timing is corret. The timing mark is on the rear of the sprocket. Do not use arrows for timing. If timing were 90° off it wouldn't run at all. The cam sprocket bolts are very tight. Torque spec is around 60ftlbs IIRC. Put the old belt on the sprocket then wrap the belt around the crankshaft sprocket, pull it tight, and clamp it to itself with vice grips. That should hold the sprocket while you loosen the bolt. Using the belt with the vice grips worked like a charm! Thanks so much! Quote Link to comment Share on other sites More sharing options...
