logic23 Posted September 24, 2015 Share Posted September 24, 2015 I have a customer (actually a couple of customers) that is/are having an issue with getting the tank to fill. This is an 03 forester 2.5 sohc. When they go to fill up the pump keeps cutting off like the tanks full. I did a quick filler neck swap ( a good used one) and it has the same issue. Could it be a vent hose that isn't letting the tank pressure vent? Any help is much appreciated. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted September 24, 2015 Share Posted September 24, 2015 I have a customer (actually a couple of customers) that is/are having an issue with getting the tank to fill. This is an 03 forester 2.5 sohc. When they go to fill up the pump keeps cutting off like the tanks full. I did a quick filler neck swap ( a good used one) and it has the same issue. Could it be a vent hose that isn't letting the tank pressure vent? Any help is much appreciated. http://www.ultimatesubaru.org/forum/topic/153786-hard-to-put-gas-in-tank/ Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 24, 2015 Share Posted September 24, 2015 Mine does not jive with the newer spring loaded pumps; also I have a slight leak which varies greatly depending on new vs. old pump. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted September 24, 2015 Share Posted September 24, 2015 I still haven't figured out what is wrong with mine. I just learned to fill it real slow. Sucks taking 10 minutes to fill the tank. Quote Link to comment Share on other sites More sharing options...
subakev Posted September 24, 2015 Share Posted September 24, 2015 (edited) I also have this problem intermantly with 95 ej22 Edited September 24, 2015 by subakev Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 24, 2015 Share Posted September 24, 2015 (edited) I have read about these issues extensively. (and, my MIL's 2011 Forester had to have the tank replaced for this!)there are at least 2-3 ways this can happen generally, with 4-5-6 causes.one thing to ask your customers - and they need to be honest to help with diagnosis - do they 'top-off' when they fill the tank. The charcoal canister can become flooded to the point it weighs pounds more than normal and blocks proper venting.the evap 'drain' hose could be clogged - it actually can allow air/fumes to travel in 2 directions depending on system requirements. But, if insects or mud has clogged the hose's outlet, it may lead to a problem like slow filling.If a bad attempt at siphoning fuel was ever made,if the filler neck is rusted in certain ways, that can cause issues.if certain evap solenoids/valves are bad, that can cause issues.if a car sits unused for a long time, the tank's vent valves can stick.some people just live with the problem, some have discovered that rotating the pump's hand 45*s to the side when filling helps.it's crazy. Edited September 24, 2015 by 1 Lucky Texan 1 Quote Link to comment Share on other sites More sharing options...
logic23 Posted September 25, 2015 Author Share Posted September 25, 2015 Thanks everyone ... All the cars that are having this issue sat for some time. So im guessing its a vent /tank issue. I will investigate on some tanks i have to figure out how to "free" the stuck valves. THANKS AGAIN Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2015 Share Posted September 25, 2015 maybe some Berryman's B-12 or BK44 w'ever in the tank would un-stick any stuck components? def. look for signs of insect activity in the ends of the evap hoses in the back. read this! ;http://forums.nasioc.com/forums/showthread.php?t=2554768 good luck Quote Link to comment Share on other sites More sharing options...
logic23 Posted September 25, 2015 Author Share Posted September 25, 2015 maybe some Berryman's B-12 or BK44 w'ever in the tank would un-stick any stuck components? def. look for signs of insect activity in the ends of the evap hoses in the back. read this! ;http://forums.nasioc.com/forums/showthread.php?t=2554768 good luck Thanks, I have some gas tanks. I was going to dismantle the vents and see which way i need to put air or suction to free them up or where to pour some "stuff" to unclog Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2015 Share Posted September 25, 2015 Honda element problem; http://takakiauto.com/blogs/kunio/emission-fail-spider COOL - please let us know what you find OK? Quote Link to comment Share on other sites More sharing options...
logic23 Posted September 25, 2015 Author Share Posted September 25, 2015 ill let the world know Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 26, 2015 Share Posted September 26, 2015 As Texan said, lots of causes for this. Easiest check is the air vent for the canister. Spiders/bugs build nests in them and clog them up. On older cars the canister vent has a separate round filter mounted above the canister. Pull the hose off of that and see if it will take fuel. If it doesn't, pull the hose off the canister itself and try. If the car has the canister with the built in rectangular filter on the end, there is a valve built into or otherwise attached to the canister that should be checked for operation via putting the ECU in test mode. Make sure the valve clicks. If it doesn't the valve is probably stuck closed. Try filling with the vent hose removed from the canister. If it fills with the hose removed the canister needs to be replaced. Quote Link to comment Share on other sites More sharing options...
logic23 Posted October 7, 2015 Author Share Posted October 7, 2015 update... I have been able to get two of the cars in that are having the issue. I disconnected the big hose off the canister that comes down from the main vent on the tank and they both fill up no problem... on to the next junction. Quote Link to comment Share on other sites More sharing options...
