espey_16
Rough idle, & check engine light.
COULD BE THE MAP SENSOR NEEDS CLEANING OR THE OXYGEN SENSOR  NEEDS REPLACEING AND SOME TIMES THE TEMP SWITCH QUIT  AND THE COMPUTER WON,T WORK RIGHT .. MAP SENSOR CAN BE CLEANED BUT OTHERS NEEDS REPLACED
Share this post
Link to post
Check timing belts could have jumped its a long shot. check if its arching anywhere start it up at night and look around a spray bottle will help if you can' see any arching
Share this post
Link to post
On 8/7/2018 at 3:49 PM, czny said:
Found this while reading today:
I found the tps in this post for about $260 at autozone. So just to be sure I'll be doing this right, I need to de-solder the stock connector on the harness. Then clip the square connection off the sensor, and solder the wires from the connector to the stock harness?
Share this post
Link to post
I bought that tps, itll be here by 3 today. After I get it soldered on and figure out how to adjust it I'll report back.
Share this post
Link to post
Well that was a success. I cut the connector off the new TPS, and the connector off the stock harness then soldered everything together. The car drove better on my test run than it has the entire time I've had it. The only difference between the 2 was the new TPS has a white wire instead of a green wire like the stock harness has. If anyone is looking for a new TPS, it's part # TPS4085.
  • Like 1
Share this post
Link to post
Create an account
Register a new account
Sign in
