92 loyale wont start! Help!
Hey guys i recently purchased my 91 loyale 4wd 5 speed and pulled the engine to fix its many oil leaks and do head gaskets and such. Well i put it all back together and it just cranks but wont turn over i have checked timing replaced cap and rotor cleaned out all the plugs i am getting fuel compression and a slightly weak spark but cant figure out why its weak! Thanks in advance for the help!
Hey guys so i checked everything that you suggested and cleaned out all connectors and everything. I also replaced the coild cuz it was old and looked a little leaky. I got one little gurgle from the exhaust right when i tried to start it and then nothing again. I rechecked all the timing and it still looked fine except for when we re did it the closest we could get ut was a little under half a tooth off but didnt think anything of it.
Edit:
You said that timing was checked but did make sure that engine was at TDC rotor on #1 ??
Edited by superpoo93
So i tried to find the three hashmarks for the timing but cannot find them for the life of me i cleaned off the flywheel even though ut was lretty clean to begin with as i just replaced it with one from oreillys. But i can only find the numbered timing marks
