wagonist Posted November 10, 2016 Share Posted November 10, 2016 Still working on template for the backing plate adaptor. Impending baby arrival has meant this dropped down the priority list a bit... Quote Link to comment Share on other sites More sharing options...
dfoyl Posted November 10, 2016 Author Share Posted November 10, 2016 I will run another set as long as there is interest. Supplier is happy to make in batches of 20 (10 pairs). Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted November 11, 2016 Share Posted November 11, 2016 (edited) Crazyeights - I'd be happy to have them shipped to me and we can either meet up or I can flat rate the hubs to you. Let me know what works for you. Dfoyl - I know you addressed it earlier in this thread, but do you plan on doing any additional runs of these hubs? @Dfoyl Thank you for all of your hard work and time. @Carfreak85 That would be Awesome Thank you for offering! Edited November 11, 2016 by Crazyeights 1 Quote Link to comment Share on other sites More sharing options...
ausmattw Posted November 16, 2016 Share Posted November 16, 2016 Confirm on the list, although Adelaide is still in South Australia, last time I checked... Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted November 20, 2016 Share Posted November 20, 2016 Sorry for taking so long to get back to you Dfoyl, I've been without a PC for awhile. Grab me a postage quote to Casino, NSW and work out how much I owe, PM me your Bank Details and i'll fix you up asap. Quote Link to comment Share on other sites More sharing options...
Brownie586 Posted December 11, 2016 Share Posted December 11, 2016 I would like a set with new studs if any more are available. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted December 12, 2016 Author Share Posted December 12, 2016 Hi guys, I've had a few queries on the status of these and sort-of posted in Brownie586's thread. Short update is the hubs were made (by mistake) with XT6 stud holes and I only found this out when the EJ studs arrived. So I had to order XT6 studs (drilling or reaming out the holes to the correct size here would be prohibitive, as the drill would be a custom-made unit (ironically I work for a (large) company that makes machines that make drill bits, but they don't sell internally so a custom-made bit would be a few hundred dollars for a one-off use from one of our customers), which are not held in stock in 100-off volumes. After some mucking around with Rockauto's customer service team, they eventually got in 100 pieces and they will be shipping across the Pacific shortly. There will be a slight price increase as the XT6 studs are more expensive AND more expensive for shipping (about $5 a pair). Quote Link to comment Share on other sites More sharing options...
ausmattw Posted December 12, 2016 Share Posted December 12, 2016 Thanks for the update. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 12, 2016 Share Posted December 12, 2016 What are the physical differences between XT6 and EJ lug studs? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 12, 2016 Share Posted December 12, 2016 The stud length and knurl size are slightly different. Legacy type studs are much more available than the xt6 style. XT6 M12-1.25 Serrated Wheel Stud; 12.45mm Knurl; 43mm Length Legacy M12-1.25 Serrated Wheel Stud; 14.43mm Knurl; 41.5mm Length Quote Link to comment Share on other sites More sharing options...
dfoyl Posted December 13, 2016 Author Share Posted December 13, 2016 Spot on. The correct drilled size for a Legacy stud is 14.43 - 0.005" (according to Dorman and similar), which is a bit smaller than 9/16" drill size and larger than 14mm, hence custom size. The Legacy stud thickness is the same as the XT6, it's only the knurled area that steps up. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 13, 2016 Share Posted December 13, 2016 As I understand it, the OD of the knurl is 14.43mm, but it's supposed to be an interference fit. It might be designed for a 14mm hole. I know when I did my 6-lug conversion, I drilled smaller than the OD of the knurl, and it worked perfectly. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted December 14, 2016 Author Share Posted December 14, 2016 The drilled size should be 14.13 (minimum) to 14.31mm (maximum), based on manufacturer's specifications for the design. Using a 14.0mm drill will mean the stud will be distorted when pressed into the hub (or the hub will be distressed and could distort). Using a size greater than 14.31 will mean the stud is not secured and will turn. That said, I'm happy for anyone to buy them without studs (saves me doing it, which takes me about 20 minutes a hub and I am not charging for my time) and do it themselves but if they damage the hub while pressing in oversize studs then it's their problem... Quote Link to comment Share on other sites More sharing options...
ausmattw Posted December 14, 2016 Share Posted December 14, 2016 (edited) I'm happy with the proposed studs. They are functionally the same and I'm never (hopefully) going to need to replace a stud so it won't be an issue as far as I'm concerned. Cheers, Matt Edited December 14, 2016 by ausmattw Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 14, 2016 Share Posted December 14, 2016 The drilled size should be 14.13 (minimum) to 14.31mm (maximum), based on manufacturer's specifications for the design. Using a 14.0mm drill will mean the stud will be distorted when pressed into the hub (or the hub will be distressed and could distort). Using a size greater than 14.31 will mean the stud is not secured and will turn. That said, I'm happy for anyone to buy them without studs (saves me doing it, which takes me about 20 minutes a hub and I am not charging for my time) and do it themselves but if they damage the hub while pressing in oversize studs then it's their problem... Fair enough. Sounds like you've put way more research into this than I did....I know I just guessed on a drill size a bit smaller than the knurl of whatever studs I used (I don't remember either dimension). It helps that that is not a street-driven vehicle.... Carry-on. Quote Link to comment Share on other sites More sharing options...
wagonist Posted December 14, 2016 Share Posted December 14, 2016 And I know of someone who's had EJ studs fitted onto an XT6 without any mods. Really big press? Quote Link to comment Share on other sites More sharing options...
dfoyl Posted January 9, 2017 Author Share Posted January 9, 2017 Hi all, As a final(?) update on this thread, I'd like to thank those members who have purchased a set and if there is anyone I missed please contact me as I still have 3 sets (all with studs) left (pending responses from those below). Confirmed with sets: US : Crazyeights (Jeff) & carfreak85 (Galen) - delivered to Jeff last week AUS : Callummcfetto (Callum) & ANIM_Hooneru (Owen) - shipped last week AUS : turbo-brumby (Gareth) - delivered this morning. AUS : grumpybrumby (Simon) and ausmattw (Matt) - awaiting payment Pending: AUS : Bantum / Elfreddo (Bennie) / LShep351 - all waiting on reply Once I get confirmation I'll put up a FS post for the next batch in the FS section here. 2 Quote Link to comment Share on other sites More sharing options...
ANIM_Hooneru Posted January 9, 2017 Share Posted January 9, 2017 (edited) Received my hubs today, hoping to have them fitted up Wednesday arvo. I will post photos and I am super stoked. If you make a 2nd run I will grab another pair as I am contemplating getting GC8 running gear under my old Leone. Thanks heaps Dean!! Edited January 9, 2017 by ANIM_Hooneru Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted January 9, 2017 Share Posted January 9, 2017 Just wanted to post here about these hubs. I was extremely impressed with the packaging, to start with. I didn't expect the hubs to be nested in a custom cut foam insert, or soaked with oil in plastic bags.I'm very impressed not only with the packaging, but the quality seems top notch too, if not OEM-quality. The machining looks nice and tight, sharp tools were used to make the cuts and all the studs look to be pressed in square. Dfoyl, thank you so much for taking on this project! 3 Quote Link to comment Share on other sites More sharing options...
Bantum Posted January 10, 2017 Share Posted January 10, 2017 Thanks for the offer Dean, PM sent. Quote Link to comment Share on other sites More sharing options...
superbrumbyman Posted January 17, 2017 Share Posted January 17, 2017 Hey, i'm super new. I'm really keen to get a set of newly studded ones for my Brumby, potentially a second set for my Leone. Hopefully there's enough interest for you to run a second batch. Thanks so much to everyone involved for the hard work thats gone into these, I can't express how happy I am to have found this thread cheers, Michael. 1 Quote Link to comment Share on other sites More sharing options...
ausmattw Posted January 21, 2017 Share Posted January 21, 2017 Received my hubs this week. Great work Dean! Now, who said they were working on a template for the backing plate mods......???? Quote Link to comment Share on other sites More sharing options...
Bantum Posted January 21, 2017 Share Posted January 21, 2017 Looking for pictures of the new hub ( not previously posted ) + it would be good to see some install pictures to ... Cheers, Bantum ... Quote Link to comment Share on other sites More sharing options...
dfoyl Posted January 21, 2017 Author Share Posted January 21, 2017 Oops, I forgot to take photos. They are all gone now. Hopefully one of the new owners will take some photos of the install. . 1 Quote Link to comment Share on other sites More sharing options...
wagonist Posted January 22, 2017 Share Posted January 22, 2017 Received my hubs this week. Great work Dean! Now, who said they were working on a template for the backing plate mods......???? Yeah well, you come round and fix my computer and then babysit my 2 month old and we'll see what I can do about that Quote Link to comment Share on other sites More sharing options...
