Txakura Posted December 23, 2015 Share Posted December 23, 2015 Co-worker has a 2004 Forester with 205/60-16 bad tires for snow. I have 1990 5 bolt rims with 195/75-14 very new super aggressive snow tires. The outer tire diameter is within reason, the width a little less than I'd like. The real question is will the calipers/rotors on his car will clear the smaller rim inner diameter. Yes we can try it and see if it fits, but I can see if anyone posts and save a hassle too Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 23, 2015 Share Posted December 23, 2015 Nope. You might be able to fit a 15" wheel but a 14" won't fit. Quote Link to comment Share on other sites More sharing options...
wtdash Posted December 23, 2015 Share Posted December 23, 2015 (edited) 16" minimum wheel. All 2003+ Foresters had min.16" wheels, Per Cars101.com Wheels/Tires X - 16" Steel, M&S 215/60R16 Raised white letter XS 16" Alloy, M&S 215/60R16 Raised white letter And bigger front disc rotors: Forester X - 11.4" vented front disc with dual caliper piston, 9" rear drum. Forester XS - 11.4" vented front disc with dual caliper piston, 10.3" rear disc, with EBD Electronic Brake Force I've read about some 15" 'rally-style' (as in WRC) wheels, but none that were stock on Subarus, AFAIK. GL, TD Edited December 23, 2015 by wtdash Quote Link to comment Share on other sites More sharing options...
Txakura Posted December 23, 2015 Author Share Posted December 23, 2015 Thanks. Quote Link to comment Share on other sites More sharing options...
