Frank B Posted August 24, 2004 Share Posted August 24, 2004 And, would the bolt pattern be the same for EA81 and EA82 tranny's(can't remember). Did you have any issues with the radiator mounting or hook up? Did you just add an in-line high psi fuel pump for the FI? Thanks Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 24, 2004 Share Posted August 24, 2004 The bolt patterns on the EA81 and Ea82 are the same. Here's a link to Mudrats prop; EJ adapter plate Quote Link to comment Share on other sites More sharing options...
SuBaRiNo Posted August 25, 2004 Author Share Posted August 25, 2004 "Did you have any issues with the radiator mounting or hook up?" Used existing radiator... modified with tripple core and inlets were made larger and bent in the appropriate directions. "Did you just add an in-line high psi fuel pump for the FI?" Yes i used a high pressure fuel pump and from there to the engine, high pressure fuel lines were used. I should have a site up soon outlining the conversion. Dave Quote Link to comment Share on other sites More sharing options...
Frank B Posted August 25, 2004 Share Posted August 25, 2004 Thanks. I have a 90 legacy in need of a tranny, but I may try to pick up an older model and use the legacy as a donor instead. Thanks again for the info. Quote Link to comment Share on other sites More sharing options...
JonOfScio Posted August 25, 2004 Share Posted August 25, 2004 I miss my hatch now. *sniff* Quote Link to comment Share on other sites More sharing options...
saeble Posted September 14, 2004 Share Posted September 14, 2004 If someone can send me a very accurate drawing of the adapter plate for this conversion, (and any adapter plate I guess), I could digitise it and then cut them professionally with A CNC water jet cutter. They could be made to look almost stock, such is the nice finish a water jet will give you. Best bit about it is they are reproduceable, anywhere. I have a pal in the states who does CNC cutting, so you Yanks need not miss out either, (I'm in AU). Jet cutting isnt too cheap but considering the month of Sundays cutting one of these adapters by handwould require... it is probably well worth it. I cant get an accurate quote without a file to quote from but I'd be happy to do the digitising and arrange a quote for nix. There also may be some advantage in economies of scale. If I work out the best way to lay them out on the sheet, it may be possible to cut lots from the one blank. If any of you guys want to try and swing a semi-commerical sort of deal, just give me a shout. If there are any other brackets and doo-dads you may require in ally or steel then by all means ask. Just be aware it sometimes isnt cheap unless you are cutting lots of the said item. Mind you, the finish is perhaps better than factory stamped components when its done well. Not to mention I can punch weight saving from them, add a simple logo even.. Just let me know ! Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 14, 2004 Share Posted September 14, 2004 This is sweet.. Almost cool enough to put lift plans on hold for another year but not quite..There are a few people up here that would skin me alive! mike Quote Link to comment Share on other sites More sharing options...
ezapar Posted September 14, 2004 Share Posted September 14, 2004 This is sweet.. Almost cool enough to put lift plans on hold for another year but not quite..There are a few people up here that would skin me alive! mike First in line! Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 14, 2004 Share Posted September 14, 2004 I would love a water jet cut adapter plate too. Quote Link to comment Share on other sites More sharing options...
Frank B Posted September 14, 2004 Share Posted September 14, 2004 I would just like a template. Made out of stiff paper so I can transfer it to the metal. And I'd pay for it too! How crazy is that?? I can use the shop I work at to cut it, that's no bother. I would love a water jet cut adapter plate too. Quote Link to comment Share on other sites More sharing options...
SuBaRiNo Posted September 15, 2004 Author Share Posted September 15, 2004 Ok fellas... due to the increasing interest in this conversion i have started making a web site covering everything i did and how to do it. It will also include a "Make your own" template and adapter plate section which most will find very very handy. The web site will also include mods like fitting air adjustable suspension to the rear end of MY subies and other stuff... I have lots of photos i will be adding that can be downloaded in high resolution. The pics alone are enough to give most people the idea of how to do things. With the pics i will have written explanations including part numbers of parts i had to by and references to extra information in Subaru manuals. This web site wil also be very handy for people doing the same conversion to L-series subarus... the methods used are similar. For anyone that is interested i have a few new photos of my subi playing about in the mud... they can be seen at.. http://community.webshots.com/album/183363690FESBfg Site should be up in about a month.. possibly less... i will post when complete. Dave Quote Link to comment Share on other sites More sharing options...
Frank B Posted September 15, 2004 Share Posted September 15, 2004 Dave, your awesome! That's what this site is all about man, sharing the info and playing for the team. I'm looking foward to the info, hopefully I will do the swap this summer, or your winter, HA! :cool: Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 28, 2005 Share Posted January 28, 2005 bump due to current interest.. can this get moved to retrofitting please? Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 28, 2005 Share Posted January 28, 2005 I am surprised that this isnt in the usrm archives for conversions of "frankenstein" nature, I have only been thinking about this conversion for about 3 months, cant wait to get done and help out with a write-up..............I need a life. ~Josh~ P.S. oh btw bump for all the converters out there.........i feel your pain. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 28, 2005 Share Posted January 28, 2005 heh. i've been working on my own cars (9 cars over 7 years) and i've learned a lot about them, but i've learned more about patience Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 28, 2005 Share Posted January 28, 2005 Im sure if you sent one to Mudrat, he could make more for everyone else. Glad to see the swap, and the answers about the 12mm difference also make it sound pretty straightforward. I was thinking of putting a EJ22 into my RX. I'll need to do more research, anyone know if the engine crossmembers on EA81's and EA82's are the same? -Brian Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 29, 2005 Share Posted January 29, 2005 im 22, i have to earn my patience through many a skinned knuckle yet to come, im too young for patience, i might have ADD, or i could just be on crack and not even know it. ~Josh~ Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted January 30, 2005 Share Posted January 30, 2005 As some of you know i have a 1983 Subaru Hatch which is rather rare in Australia due to hatches never being released here.where did you import the hatch from? i wasn't aware they where made RHD(edit) just read couple off your other posts an got all my questions answer'd Quote Link to comment Share on other sites More sharing options...
lepetitprince Posted February 4, 2005 Share Posted February 4, 2005 Did anyone from board recieved the sample plate from Subarino? Dan Quote Link to comment Share on other sites More sharing options...
ballitch Posted February 4, 2005 Share Posted February 4, 2005 its not hard to make your own, the bottom holes of the EJ22 motor and the EA series trannys line up perfectly, with that said al oyu have to do is use some 1/8'' plywood and make a pattern, drill out your dowel pin holes, on motor and tranny, and lay out the bolts for the motor and tranny, look in the EA to EJ conversion condensed thread for a link i posted about subarinos conversion, many a question will be answered. after you have a working pattern get yourself some 1/2'' steel or aluminum and cut it out, if you use aluminum you have to cut it with plasma cutter, and nothing else. if oyu dont, your adapter plate will warp because of the heat from a torch or acytelene cutter. ~Josh~ Quote Link to comment Share on other sites More sharing options...
Matty B Posted June 27, 2005 Share Posted June 27, 2005 after you have a working pattern get yourself some 1/2'' steel or aluminum and cut it out ~Josh~ 1/2 inch is not quite 12mm Ballitch. I would skim the extra 1/2 mm off at the end with a belt sander or thicknesser. Too much to go wrong by just 'rounding up to 1/2 inch'. These are METRIC cars dude! Get with it, the rest of the world has. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted June 27, 2005 Share Posted June 27, 2005 I used a scroll saw and a half-package of metal blades to cut mine. The edges aren't as nicely finished as I'd prefer but I will spend some time with a file and clean them up. I have yet to drill and tap the holes for the engine but I have drilled and tapped the holes for the transmission. I have my XT6 flywheel at a machine shop - I found someone to mill out the holes to match the EJ22 crank for $40-$50 ... one shop quoted me $180 - I waited until I had politely thanked them and hung up before laughing. you use aluminum you have to cut it with plasma cutter, and nothing else. if oyu dont, your adapter plate will warp because of the heat from a torch or acytelene cutter. ~Josh~ Quote Link to comment Share on other sites More sharing options...
ballitch Posted June 28, 2005 Share Posted June 28, 2005 i would have used 12mm aluminum...but all i could find around town was 1/2'', after all 1/2'' is 12.700 mm...not to far off. works great. hope to see more EJ converted rides at WCSS7. ~Josh~ Quote Link to comment Share on other sites More sharing options...
Tbird Man Posted June 28, 2005 Share Posted June 28, 2005 1/2 in should work, the extra just means a little less of the input shaft in the bushing. though if you can get 12mm it would be preferable. I might do this to put a 5spd D/R in a 'Prezza. Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted June 30, 2005 Share Posted June 30, 2005 im actually currently working on getting the adapter kit from mudrat right now.... i just cant wait to see the faces on all my buddies with jeeps and trucks when i tell em im goin wheelin with em..... im hoping to be running some 7" of lift, and then some 30x9.5/15's...... should be done by the end of the summer, i hope.... Quote Link to comment Share on other sites More sharing options...
