Srubendall Posted June 2, 2016 Share Posted June 2, 2016 91 loyale wagon runs and starts first time. After driving for 10 minutes turn off won't restart. Turns over, have spark, have fuel. Checked all plugs and fuses. Let it sit for a couple of hours and no problem restarts and drives fine. 1 Quote Link to comment Share on other sites More sharing options...
colemanapp Posted June 2, 2016 Share Posted June 2, 2016 Hmmm, Sounds like when my distributor went south. Quote Link to comment Share on other sites More sharing options...
Dee2 Posted June 2, 2016 Share Posted June 2, 2016 I googled this: subaru won't restart when warm found a lot of similar discussions. Many point to the sensors. You might recognize some of their symptoms to help narrow it down. Quote Link to comment Share on other sites More sharing options...
Rust Posted June 2, 2016 Share Posted June 2, 2016 been struggling w/ the same issue. have replaced everything except the distributor. Funny it is not a problem in the winter, only in the summer. Quote Link to comment Share on other sites More sharing options...
colemanapp Posted June 2, 2016 Share Posted June 2, 2016 The distributor gets hot and stops working best I can tell. I blasted mine with a freezing spray when it was hot and wouldn't start. Fired right up when its cooled down Quote Link to comment Share on other sites More sharing options...
Srubendall Posted June 2, 2016 Author Share Posted June 2, 2016 Replaced distributor last month, replaced coolant temp sensor. Still no restart when hot Quote Link to comment Share on other sites More sharing options...
Alwaysnextyear Posted July 15, 2016 Share Posted July 15, 2016 You ever figure it out? Quote Link to comment Share on other sites More sharing options...
turfman454 Posted August 7, 2016 Share Posted August 7, 2016 (edited) just for thought i was having the same problem. It would run great until it warmed up. There is a thermo valve inside the air filter housing . When it opened up i had a huge vacuum leak. plugged it up no more problems. Should be on the drivers side of the housing Edited August 7, 2016 by turfman454 Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted August 10, 2016 Share Posted August 10, 2016 Coolant temp sensor went out on my sisters ej22, did the same thing you're describing. Quote Link to comment Share on other sites More sharing options...
