Victor.Vector Posted June 5, 2016 Share Posted June 5, 2016 As the title says, I'm curious as to what rim/tire combinations are available if you're running a stock height Loyale. I've read the Official 6-Lug Re-Drill Thread, but most of the posts on there seem to be related to cars with lifts. Pictures would be very appreciated! Thank you! Quote Link to comment Share on other sites More sharing options...
dfoyl Posted June 7, 2016 Share Posted June 7, 2016 (edited) I think your problem will be offset, as most 6-stud donors will not fit under the wheel-wells on a Loyale (they will just fit on a MY). If you have fender flares you'll be fine of course (I know US laws are a lot more lax than down under, which says the wheels MUST be inside the fender line). I used Pajero (US = Montero Sport) 16" wheels which were ok for an MY (except they weigh a ton). I *recall* Ford Courier utilities were one option which may work for a Loyale. If you're concerned about speedo accuracy, you will need 195-50-15's or 195-45-16's to maintain within 1% (I can't recall 14's, but if you wanted 14's you'd be best sticking with Pug 504's than moving to 6-stud). Edited June 7, 2016 by dfoyl 2 Quote Link to comment Share on other sites More sharing options...
wallaby Posted June 7, 2016 Share Posted June 7, 2016 not certain about a loyale, on my Brat i have stock 2wd mazda 14" alloys with 195/75 R14 tires they work perfect with out any lift, no rubbing a 205/75 on the same rim will rub.... for reference you can fit a 245/60R14 on the back.... so any stock offset 6 lug jap pickup(mazda, nissan) rim would work- most 2wd will have 14" wheels Quote Link to comment Share on other sites More sharing options...
spazomatic Posted June 22, 2016 Share Posted June 22, 2016 I used Isuzu pickup rims. But they do stick out and would not work at stock height. Since I'm at stock height, I had Dr. Sawsall adjust the fenders. 3" from the diameter of the front, and 1.5" from the rear. Now I can run 205x75-14s with no rub. mines an 84 GL, but the same principles apply. Quote Link to comment Share on other sites More sharing options...
