Hi, I know this question has been asked a lot on this forum however I aim to do as much research as possible into everything I do so I get it right the first time. I am on a fairly tight budget and would like to know a few things.
1. Will I be able to use the ej18 intake runners on the ej22 P2 block to get it to work
2. Will I be able to use the ej18 flywheel and clutch on the ej22 for the time being
3. Will the transmissions bolt up or will I need to install a different transmission
4 can I just get rid of the knock sensor and it (ej22) run fine
Kind regards~Abid
