Skippy213 Posted August 19, 2016 Share Posted August 19, 2016 I recently had a hose rupture on the driver rear side of the vehicle, went to pick up some 5/16 injector hose with high pressure clamps. replaced 3 of the four hoses and now it leaks like to much presure build up. Curious if anyone has a photo or a good diagram of the how these should be connected and also what is the plastic part back there? Could it be the air evap ? The car starts and runs but spits fuel everywhere from the fittings and now further up towards the passanger side of the tank. any help would be appreciated. Link to comment Share on other sites More sharing options...
Skippy213 Posted August 24, 2016 Author Share Posted August 24, 2016 So I have fuel lines broke from pump I can not see them, I know there is one other part, does anyone have a diagram of the lines and hoses from the pump to the second pump to the tank? I am just going to replace the lines with injector hose but need to know which ones connect where. Link to comment Share on other sites More sharing options...
