brownie Posted September 3, 2016 Share Posted September 3, 2016 Mine is old and cracked, sometimes leaks water vapor, anyone know where to get these discontinued items or how to fix an old one with a broken circle? Thanks Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 3, 2016 Share Posted September 3, 2016 Maybe an o ring? Or gasket sheet blank. Or sheet rubber of your choice. I have bought sheets from mcmaster Carr and MSc direct. Then cut to match. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted September 4, 2016 Share Posted September 4, 2016 RTV 1 Quote Link to comment Share on other sites More sharing options...
brownie Posted September 4, 2016 Author Share Posted September 4, 2016 Thank you. RTV is ok to use in that environment? Quote Link to comment Share on other sites More sharing options...
turfman454 Posted September 5, 2016 Share Posted September 5, 2016 no rtv just make a paper gasket 1 Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted September 5, 2016 Share Posted September 5, 2016 Thank you. RTV is ok to use in that environment? Yes. Also depends on what one you use. Many off road guys use it to seal things like the distributor cap because sometimes their whole engine is under water. Quote Link to comment Share on other sites More sharing options...
Dwayne Oxford Posted August 5, 2018 Share Posted August 5, 2018 (edited) What is the part number for these? https://www.subarupartsdeal.com/parts/subaru-sealing-distributor~491787202.html?Make=Subaru&Model=GL+Series&Year=1985&Submodel=&Filter=(2=GL) Edited August 5, 2018 by Dwayne Oxford Found and posted # Quote Link to comment Share on other sites More sharing options...
