dp213 Posted November 13, 2016 Share Posted November 13, 2016 I have seen some people running their Subarus without any timing covers, front or back plastic. Isn't that trouble waiting to happen. Quote Link to comment Share on other sites More sharing options...
montana tom Posted November 13, 2016 Share Posted November 13, 2016 I wouldn't do it on an 2.5 motor ... but on a non interference 2.2 , other than losing a finger .... nothing much would happen. Some offroader's say it keeps snow and mud from building up under the plastic. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted November 13, 2016 Share Posted November 13, 2016 Once you delve into the engine work, it becomes a matter of personal preference. In this case, I am one of those that feel it's there for a reason, so I keep mine on. O. Quote Link to comment Share on other sites More sharing options...
lmdew Posted November 14, 2016 Share Posted November 14, 2016 Good covers and no leaks keep things nice and clean and rust free. Quote Link to comment Share on other sites More sharing options...
JPX Posted November 16, 2016 Share Posted November 16, 2016 My CA based 96 Legacy has not had front timing covers since I replaced the long-block several years ago. It's true the timing belt and the pulley surfaces get a little grubby. But the probability of a negative consequence is lower given the posh street life the car enjoys (no gravel, mud, snow, hard driving and low chance of bad rust). I gave up on the covers after a rough roundy-round with the crankshaft pulley keyway and a more recent head gasket debacle. I wouldn't recommend running without covers for most users. But if you are at the point of taking your engine apart anyway, then it is a personal choice. My choice is based on the fact it is more likely I have to take something apart anyway before I encounter a problem caused by a missing belt cover on my $1000 KBB-value Subaru! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 16, 2016 Share Posted November 16, 2016 I run both of my old 2.2s without them. No chance of bent valves on the pre-96 2.2. But I also keep a full timing kit of used timing pulleys and an old belt in the trunk. Takes me less than 45 minutes to do a timing belt and pulley change. On an interference motor I would keep the covers on. Quote Link to comment Share on other sites More sharing options...
