Stock radio questions
Got a stock radio from a jy car and I was wondering if anyone knew what the round connection on the back is, I'll put up a picture when I'm home.
I also ordered new antenna wire but I don't know how I should solder it to the board. I already de-soldered the wire that was on there but I can't remember if it was the inner wire or the braided wire that was that was actually connected. I want to say that the braided wire is what was making the connection but from my understanding it's the inner wire that makes the connection and the braided wire acts as insulation to keep interference from coming through the speakers.
As always any help is appreciated.
Ohm meter from ground to each pin will find you gnd.
To find the L R inputs, set the radio to aux or whatever it has. Use a music player / phone headset output for a signal. To be safe, put something like a 2000 ohm resistor and a 1uf capacitor in series with the signal from the player to the pin you are testing.
